leolas
[ROM] Finless 1.7a for the UG008 (CWM flashable)
Re: [ROM] Finless 1.7a for the UG008 (CWM flashable)
Originally posted by nipper View Post
Originally posted by nipper View PostQuick question, I'd prefer to flash finless with the rom flash tool for the extra app space, would it be ok to swap the finless kernel720.img file with the one from Tony's and then flash via flash tool?
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostBe sure that both ate the same kernel version, 3.0.8 or 3.0.36
leolas.
I'll be using finless 1.7a rom from link below and swapping the kernel with Tonys.
Also, are there any underclocked kernels available for the UG008B?
Originally posted by shivup View PostGreat.. Does it work with Ugoos UM1 Rk3066 model?? I cant find another section for this specific device.. Help will be appreciated.. Thanks
Ok, I tried this with the ug008b from geekbuying and unfortunately it didn't work.
For some reason the cwm for the ug007 didn't take and left my device unbootable.
I tried re-flashing with the stock firmware and all seemed to go well (no errors during flash) but I only get a black screen when trying to boot.
I have managed to flash finless 1.7 for imito mx1/2 which works fine but doesn'r support onboard lan or A/V out. Flashing the kernel from ug007 causes boot problems.
I would really love to get lan and A/V functions back so if anyone can offer any advice it would be much appreciated.
There are currently 2357 users online. 0 members and 2357 guests.
