My modded MK809ll
    My modded MK809ll
    I noticed my MK809ll got hot when playing movies, so I took a look inside. NO Heatsink!
    So, I first added a heatsink to it and moved the antenna outside the case.
ID:	438378 Click image for larger version
ID:	438379 Click image for larger version
ID:	438380 Click image for larger version
    I was using a 7 port USB hub Click image for larger version
    with the stick and decided to do some more modding.
    I found a 5v USB fan in a £1 Laptop cooler, some 3mm perspex and some irrigation fittings and did this:
ID:	438383 Click image for larger version
ID:	438384 Click image for larger version
ID:	438386 Click image for larger version
ID:	438385Click image for larger version
ID:	438387 Click image for larger version
    In action:
ID:	438389 Click image for larger version
    Awesome!
    - UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
    - MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
    - MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
      WOW
      Great work
      My devices:
      Gearbest.com)
        Ynt: My modded MK809ll
        Awesome
        GT-N7100 cihazımdan Tapatalk 2 ile gönderildi
            Great work - looks fantastic.
              Hmmm.... I am wondering if we should make a case mod or hardware mod forum here....
              Thoughts?
                Thoughts?
                Definitely Bob - I started a thread but a full forum would be awesome.
                  Another thumbs up for a modding forum.
                  As Horrorzilla said in his other thread, feel free to move this thread if you create a new forum.
                    lol, pukka mod!
                    I'm starting to get tempted to try some kind of mod with my MK809II too. Bit concerned about the amount of heat mine kicks out sometimes without even a heatsink to help out...
                    BTW, how did you attach the heatsink to the CPU?
                      Re: My modded MK809ll
                      Originally posted by big10p View Post
                      lol, pukka mod!
                      The heatsink came with adhesive thermal tape attached.
                      Sent from my GT-I9000 using Tapatalk 2
                        It looks good!
                        But the fan is large in comparison to the heat sink. The heat sink the size of a dc motor. The fan blades will not blow air into the heatsink.
                        An efficient cooling.
                        See the picture.
                          Originally posted by csjohnny View Post
                          It looks good!
                          See the picture.
                          The fan is blowing upwards taking the heat away from the heatsink as it rises, so similar to your picture.
                          Sent from my GT-P7310 using Tapatalk 2
                            I Understand. So it works well.
                              Anyone know of a good place to get heatsinks and fans suitable for use with our TV sticks? I had a quick look on the Maplins site, but they didn't seem to have anything suitable.
                              I want to mod my MK809II, but fitting a heatsink on my version is going to be a bit tricky, as the relocated reset button (right next to the CPU!) and a resistor (I think) are raised higher on the PCB than the CPU. I guess I'd need a heatsink with a sort of platform on the bottom?!
                              Do the RAM and NAND chips also need heatsinks if running an overclock kernel?
                              Thanks.
