Would be interested to know what might have happened here if anyone has any ideas. I bought the new M8S box with the Amlogic S812 Chip from Aliexpress and got it this morning. This one to be precise.
http://www.aliexpress.com/item/Origi...368069195.html
I used the 5.0.8.18 version of OpenELEC from this link
Booted the M8S in to recovery, cleared the cache and data and then, since the box has no Micro SD card slot, I had to go to 'udisk' to select the zip file that was on the USB stick that I had plugged in, and i selected the "update" zip that's inside the main zip file as the main zip file didn't flash due to - if i remember - the 'invalid footer' (or something like that).
Everything went through and i got the message saying "Update Successful" so I rebooted the box and .. dead. Absolutely dead as a duck. Won't even power on. Won't power on by the remote either. I tried the PSU from my other Android box as it's the same voltage but nothing - box is totally fried.
I've bricked many things over the years but i've always managed to get back to some form of recovery to rescue them - this is the first time i've ever fried something completely to the point where it won't even power on. If anyone has any ideas as to why it might have happened i'd be grateful.
I'm hoping the supplier will replace the box and, ideally, i'd still like openELEC on it but not if it's going to fry it again
Thanks.
