H3 tools
General functionality is along the lines of:
Modifying boot logo, sound, animation.
Adding and removing APK's.
In the advanced section you can modify system configuration (sysconfig1.lhs), keyboard mapping, buildprop, Init.rc file.
Nothing too advanced that is beyond most users I would say.
Can someone to modify Zidoo X1 img file to be used on another H3 boxes?
There is problem with MAC Address which activate WI-FI.
Can i just to replace system configuration files from Zidoo X1 to my H3 Box?Last edited by plasma; 08 August 2015, 11:36.
Originally posted by plasma View PostCan someone to modify Zidoo X1 img file to be used on another H3 boxes?
I'm looking at that, although the tools are fairly basic.
What we need is to know exactly what WiFi chip is used in each box to try injecting drivers for total cross compatibility.
I know that the Beelink X2 uses the AP6181.
I believe that the Tronsmart H3 uses the AP6212.
With this information it will be easier to inject drivers into other ROM's.
I thought that the Mac Address was only linked to the Zdrepo site for uploading of custom Kodi repos and addons?Last edited by bluesmanuk; 08 August 2015, 14:27.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
I think thet something is checking MAC address to compare it with Zidoo database,and if your MAC address is not on the list,then your WI-Fi do not works.
One member have problems when he received his X1 with activation error,and zidoo ask him for his MAC address and in one minutes his X1 have worked.
For experiment can we just to remove thet massage over the screen or just to remove wi-fi in order to have full work over Lan port.
There are currently 2001 users online. 2 members and 1999 guests.
