OTT M8S+ running Android 5.1.1
I was able to get root on an M8S using this http://freaktab.com/forum/tv-player-...oot-zip-update
That's too bad... Are you 100% sure it's not rooted? In the past, I've had M8 boxes that looked like they were not rooted but, when I installed SuperSU, it turned out to be rooted (again different box so it might not be same case for you but, worth a try). I've also had success using Kingo root app on other device (CS918) in the past, not sure how well it would work on M8. Good luck!
Originally posted by foz View Post
when you say flash SuperSU in recovery do you mean bobs 89_root_update.zip because I've tried that and its still not rooted?
although the root checker is now saying its rooted now which is great thanks for the usb debugging bit, I can still not use apps that require root like the reboot app ssh/sftp etc
I still don't get root access because there is non binary installed?
if I open the su app I get the following message
"there is no SU binary installed, and SuperSU cannot install it, this is a problem. if you upgrade to android 4.3 you need to manually reroot consult the relevant forums for you device"
I updated the su in play store but get the same message now but says 5.0 not 4.3Last edited by foz; 02 September 2015, 09:39.
Originally posted by foz View Postalthough the root checker is now saying its rooted now which is great thanks for the usb debugging bit, I can still not use apps that require root like the reboot app ssh/sftp etc
What image do you use on the m8s+ running lollipop 5.1?
I have tried the archive from chinagadgetsreviews, after installing this i am stuck in the amlogic logo.
When i flash from android system recovery i get a warning about /misc that can not be mounted.
Can anyone send a link with a working update please ?
Thx
Originally posted by Pietjepuck View PostWhat image do you use on the m8s+ running lollipop 5.1?
Thx
are you flashing a +Plus box because it wont work on M8S unless you edit the firmware?
and 5.1.1 I found a real pain to try and edit
after hour of reading on xda and playing I was still not able to build it back up correctly.
There are currently 4247 users online. 0 members and 4247 guests.
