Draco AW80 A new build found 29.08.2015 android 4.4.2
    Found this over at 4pda
    New build from 29.08.2015 android 4.4.2
    Interface port draco H3.
    The core of the RKM_0627 set of programs unchanged, added Kodi 14.2
    To avoid problems with the management made ​​2 versions: for Draco to RKM everything else was the same. With the possible RomToolBox flash bottles with another nucleus, (in the archive of the kernel firmware RemixOS 1 and 2, draco_0523, TBS, RKM0627) maybe someone will be interested. PS TWRP complete post has been edited danilov_sa - Yesterday, 21:19
    https://yadi.sk/d/NDkXQS6Xijgxg
    Netflix works with out fighting with lower taskbar...
    No issue yet with google play services and USB keyboard.
    Has Root
    Interesting.....
    Cheers
    It seems to be a russian firmware. I cant seem to figure out how to add and remove apps on the desktop but maybe a new launcher would do it. Live wallpapers are good. Kodi is up with all the addons as well as streaming files over LAN are working great with no stuttering or anything so far. It cant play 60fps files tho. Maybe some one can run some tests and see if overclocking would help or if it can be?
      Hold and drag to get them there.....
      Yer remove from desktop no delete when dragged up off desk area
      But minor issues
      It does work well indeed
      Cheers
        It could have been my favorite rom, but too bad, no dts passthrough in kodi 14.2.
        I installed 14.1 from Tronsmart original Rom, and no dts passthrough, only stereo !
          Maximum video capacities : 1080p 60 fps with mx player or 4k 30 fps in kodi
            Try another kernel
              Excellent Work thanks dsa13dsa ..looking good
              Cheers
                Originally posted by dsa13dsa View Post
                Try another kernel
                I don't know how!
                Could you make a new Rom from this one and make dts passthrough work?
                  dsa13dsa
                  Please better translation
                    Translated message:
                    New firmware from 29.09.2014 android 4.4.2.
                    Interface is ported from Draco H3.
                    Kernel from RKM_0627.
                    Set of preinstalled programs is unchanged.
                    Added Kodi 14.2.
                    Made two flavors for different remotes. Other than that they are identical.
                    for Draco
                    for RKM
                    You can flash another boot with a different kernel via RomToolBox.
                    (there are kernels from RemixOS 1 and 2, Draco_0523, TBS and RKM0627 in the archive)
                    Perhaps that would be of use for someone.
                    P.S. TWRP is included in the firmware.
                      Thanks for that, I was reading it that way just not 100%
                      Now to sort out Rom toolbox to do some more Magic
                      Again Thanks
                        shprota
                        As I am not 100% sure of using the Romtoolbox and the .img in boots
                        Could you assist with more information on procedure.
                          Has anyone been able to play 60fps videos on YouTube with this ROM? I was not able to play 1080p videos even with editing the build prop so i installed the OGYouTube apk and i can select 1080p now. But i still cant play 60fps videos on YouTube. It plays the audio but the video freezes and doesnt play. I remember one of the first ROMs found here on FreakTab would let you play 60fps YouTube and any network files but cant remember which one. I really like this ROM so far and wonder if anyone knows of how to flash another kernal or could refer such a kernal or even if that would even help. Any ideas?
                            Originally posted by trebor View Post
                            shprota
                            1. Start RomToolBox (You need a Google account and the online)
                            2. Launch the "Rom installer"
                            3. In the upper right corner the push button ... (three dots)
                            4. Choose a "flash image"
                            5.1 Select patrition - boot,
                            5.2 Select img to flash - choose any need from the archive (advance to unpack on sd card)
                            and click the button FLASH bottom of the screen.
                            After completion of the process need to reboot.
                              Thank You
                              I was close but did not click right corner "flash Image"
                              Easy when you know
                              Will help others as well.
                              Again thanks and great Rom
                              All good bit of a flash and a new Kernel
                              Excellent work
                              Cheers
