Q7 android cs918 its not work how can i fix it?
A power supply can test OK unloaded/loaded and still be bad. Voltage is only one parameter. Can it deliver the required volts at sufficient amps and does it do so without distortion, under load. Hard to test without specific equipment. The power supplies that come with some of these budget boxes are typically of poor quality.
I don't know what is wrong with your box, if anything, but I would try an appropriate substitute power supply. If you still have the issue with a different PS, then at least you will have ruled out a bad PS, and can focus on other areas.
Good luck.Last edited by RISCy Dude; 15 October 2015, 02:23.
Thanks for the reply. I did not install drivers. When I connect it to my pc with usb cable, windows does not show anything. I have Device Manager open and nothing show up at all, and no system sound either. The leds turn red when I connect usb to PC and stay on. I am using a regular micro usb cable. Not sure if that makes a difference.
Originally posted by TRoN1 View PostThanks for the reply. I did not install drivers. When I connect it to my pc with usb cable, windows does not show anything. I have Device Manager open and nothing show up at all, and no system sound either. The leds turn red when I connect usb to PC and stay on. I am using a regular micro usb cable. Not sure if that makes a difference.
There are currently 1862 users online. 0 members and 1862 guests.
