R8 Rockchip Octa core 64 bit 4k
    Just ordered an android tv box from geekbuying.com/
    It seems to be fast and pretty good but I cannot find any reviews yet.
    Did anyone buy this one yet or know where to find reviews?
    http://www.geekbuying.com/item/R8-An...MC-348873.html
    • Google Android 5.1
    • Rockchip R3368 Octa Core up to 1.6GHz (Cortex-A53 64bit)
    • SGX6110; support 4K*2K H.265/H.264
    • DDR3 2G Onboard eMMC Flash 8GB
    • IEEE 802.11a/b/g/n/mimo, WiFi compliant; 4.900 GHz ~ 5.845 GHz (5.0 GHz ISM Band) AP6330
    • 10/100/1000M LAN
    • Bluetooth 4.0
    • HDMI 2.0
    Specification
    Model R8
    Color Black
    Operating System Google Android 5.1
    CPU Rockchip R3368 Octa Core up to 1.6GHz (Cortex-A53 64bit)
    GPU SGX6110; support 4K*2K H.265/H.264
    RAM DDR3 2G
    ROM Onboard eMMC Flash 8GB
    Extended Storage Micro SD Card (Maximum support 32GB)
    Wifi Connectivity IEEE 802.11a/b/g/n/mimo, WiFi compliant; 4.900 GHz ~ 5.845 GHz (5.0 GHz ISM Band) AP6330
    Ethernet 10/100/1000M LAN
    Bluetooth BT 4.0
    Video/Picture Supported Main/Main10 HEVC/H.265 decoder by 4k@60FPS
    Support up to 4096x2304 resolution
    Support up to 100Mbps bit rate
    Embedded memory management unit(MMU)
    Stream error detector (28 IDs)
    Internal 128k cache for bandwidth reduction
    Multi-clock domains and auto clock-gating design for power saving
    Real-time video decoder of MPEG-1, MPEG-2, MPEG-4, H.263, H.264, AVS, VC-1, RV, VP6/VP8, Sorenson Spark, MVC
    Error detection and concealment support for all video formats
    Output data format is YUV420 semi-planar, and YUV400(monochrome) is also supported for H.264
    H.264 up to HP level 5.2:4Kx2K@30fps (4096x2304)
    MPEG-4 up to ASP level 5:1080p@60fps (1920x1088)
    MPEG-2 up to MP:2160p@30fps (3840x2160)
    MPEG-1 up to MP:1080p@60fps (1920x1088)
    H.263:576p@60fps (720x576)
    Sorenson Spark:1080p@60fps (1920x1088)
    VC-1 up to AP level 3:1080p@30fps (1920x1088)
    RV8/RV9/RV10:1080p@60fps (1920x1088)
    VP6/VP8:2160p@24fps (3840x2160)
    AVS:1080p@60fps (1920x1088)
    MVC:2160p@30fps (3840x2160)
    For AVS, 4:4:4 sampling not supported
    For H.264, image cropping not supported
    For MPEG-4, GMC(global motion compensation) not supported
    For VC-1, upscaling and range mapping are supported in image post-processor
    For MPEG-4 SP/H.263/Sorenson spark, using a modified H.264 in-loop filter to implement deblocking filter in post-processor unit
    Resolution 4K*2K
    HDMI Port HDMI 2.0
    Other Interfaces 2* Standard USB; 1*DC in Jack; 1*HDMI IN Port; 1*S/SPDIF (2CH, 5.1CH); 1*RJ45; 1* SD card slot
    Power Adapter 5V 2A
    Other Function Antenna: Built-in antenna for WIFI
    Keyboard: Qwerty keyboard
    Miracast/DLNA Support
    Support original ecology and custom UI
    Work Environment 5- 35 Degrees, 30%--90% Humidity
    Storage Environment -20 - 60 Degrees, 10%--90% Humidity
    Language Multilanguage
    Dimension 116*116*18mm
    1 x TV box
    1 x IR remote control
    1 x HDMI cable
    1 x Power adapter (A right AC Adapter will be sent as your shipping country)
    1 x User manual
    Firmware update:
    ROM Download R8 Rockchip RK3368 2G 8G TV BOX Firmware 190455 150819
      What's the difference between this and the Beelink i68?
        The price i guess
          I don't own either, but board makers maybe, Netxeon vs Sunchip or ENY?
            R8 is sunchip. Sunchip has an antenna, r8 doesn't
              OTG is not working with the driver and tool provided.
              Also tried it with the newer http://chinagadgetsreviews.com/hot-d...tool-v1-8.html
              Tried newer drivers from DriverAssitant_v4.3
              No luck.
              Win7
              OTG male male
              Sometimes a pop up saying new hardware but it refuses it.
              Nothing in device manager
              It is detected in network as a media center, tried top open through LAN.. no luck.. you only see a redirection to rockchip.com
              USB debugging is active by default on the R8
                No luck.
                Win7
                OTG male male
                Where did you purchase your otg male to male cable? I can't even get my computer to even recognize it as an unknown device.
                Also my m8s performed much faster especially with gaming.
                  No luck.
                  Win7
                  OTG male male
                  Never buy an unknown or no-name brand TV Box.
                  You are going to face lots of firmware issues that will already be fixed on other boxes.
                  And then there are also hardware problems, because quality checks are few or none existent.
                    Perhaps but its only the otg at this point. The chipset is the same as many others so no firmware issues. It works fine now without the update. The only thing I see is issues with pulsar (restart kodi message) and in popcorn are the subtitles microscopic. That's not chipset, that's software.
                    Sure I regret it, but that's because I'm impatient.
                    Still think everything will be fine, if not I'm selling it.
                      No luck.
                      Win7
                      OTG male male
                      Instructions say to Press in reset button, then plug in power, perhaps it will be seen then. The MK-808 & CX-919 had this same process to flash anything... I haven't purchased my male/male USB yet, going to radio shack today to get one (hopefully it will work?). Not happy with the device as is, I only get 720p resolution, hoping the new firmware fixes that, otherwise it goes back to china!
                      Also, the Tool you show in this thread is for the R3268, this box is R3368.
                      Anyone able to get the Batch tool to switch to English or find the instructions in English?
                      Ok, I figured out how to get the batch tool to come up in English, edit the Config.ini, line 4 to read "Selected=2" (no quotes). Then open the tool "Run as Administrator", that get's the tool open, now, if I just had a Straight USB Male/Male cable. I ran all the way to Best Buy (41 miles each way) & they didn't have one, seriously? WTF, who designs a BRAND NEW Device and makes their OTG port a FULL SIZED USB? Then DOESN'T INCLUDE THE EF-ING CABLE WITH THE DEVICE!!! No one has those cables locally because NO ONE USES USES THEM ANYMORE!! I had to order one from Amazon & wait 3 more days to get it. This BETTER work or I'm really going to lay into Geekbuying for this POS!
                      PISSED OFF in Virginia!
                        Tried that, also tried rockchips sd card tool. No luck
                        1080 crashes all the time here in popcorn. Hardware acceleration error. It's definitely not for end users.
                          At least you have a 1080 option, mine only goes to 720p!
                            Well, if you pay for an option you should get it. If I bought it in a shop I would return it straight away. This sending to china is just too much effort.
                              Doesn't matter about the cable because it won't connect to any of my PC's with the cable. I don't even hear the notification sound when you connect a usb device and my USB port doesn't light up.
