R8 Rockchip Octa core 64 bit 4k
Originally posted by Eclecticon View PostI hope someone will fix it or I'm gonna set it on fire soon and wait for the new ugoos.
I finally received a USB cable Male/Male. Tried holding reset but in while plugging into OTG port, nothing, plugging in power cable w/o USB, then plugging USB into OTG, Nothing. I notice that plugging in USB cable powers up the device (Odd?). So, knowing the Chinese have labling issues, I tried holding in reset button while plugging in USB cable (No Power plug) to OTG, nothing, USB 2, nothing, USB 1, "PONG"! Win7-64bit saw the device, but allas, it pong down a few seconds later because the Driver wasn't correct, Drivers provided "Say" they're installed, so either they are NOT the correct drivers OR there is some other, unknown issue. I'll keep efing with it to see what I can get done...
Stay tuned!
Originally posted by Eclecticon View PostI had the same but couldn't determine what action caused the pop up. After that nothing in device manager.
BTW, I have requested a RMA to return this PoS to China, awaiting their reply.
No luck with the bootable media option, still needs drivers, no drivers, no worky!
BACK TO CHINA IT GOES!!!
Now to find one that actually has some support!Last edited by Wanbli; 09 September 2015, 21:43.
Yesterday I succeed to update firmware for my CX-R8 instructions are below:
First of all you need a linux distribution, any ubuntu based distribution will work; I'm using Mint 17.2 don't waste your time with windows. You don't need to install linux, a bootable usb live distribution will be ok ( you can prepare a bootable usb using Lili )
Get the Rockchips Update Tool from HERE and extract it to the directory you want (I suggest you to extract it to the same directory with firmware update.img)
1 - OTG port doesn't work, USB-1 works connect Male(A) to Male(A) USB cable to USB port 1 beside SD card slot.
2 - Don't connect USB or power cable before press to reset button (important)
3 - Don't release reset button while you plug in Power Cable and USB cable (Both side should be connected Box-PC)
4 - Open a terminal session an run the command " ./upgrade_tool uf update.img " if you are not root command should be " sudo ./upgrade_tool uf update.img "
5 - You will see the firmware upgrade process. After successfull upgrade box will reboot, and that is it.
All instructions take about 5 minutes, after upgrade box will optimize applications it will take 2-3 minutes.
I tried Wassers rom too and I liked it much but ethernet, wifi , remote doesn't work than returned to new firmware.
New firmware works good but not rooted, not optimised, comes with Kodi 15.0 Beta, don't expect so much improvements.
Wassers kodi 15.1 apk works great,
Today I tried to upgrade on x86 windows 7 an it worked, first 3 steps are important.
of cource you have to install driver
I hope helps you to upgrade,
Kind Regards,Last edited by darkstar; 10 September 2015, 21:53.
Wow thanks! Will try it.
I cannot find a link for Wassers kodi 15.1 apkLast edited by Eclecticon; 10 September 2015, 16:11.
Originally posted by darkstar View PostYesterday I succeed to update firmware for my CX-R8 instructions are below:
Kind Regards,
Thanks! I booted into my xubuntu and everything went smoothly. No issues with detection or flashing except for of course the mislabeled OTG port. WinBlows was having driver issues.
The previous firmware seems to be better. The update seems to have lag throughout the UI. Also an issue with navigational sounds which I was able to fix by selecting HDMI bitstream instead of Default under the sound options.
Netflix doesn't play any videos. Works fine on my other devices and previous firmware.Last edited by jsergio123; 11 September 2015, 22:42.
Originally posted by jsergio123 View PostAnyone else having problems playing 1080p Blu-ray mkv's with Kodi ? Every time I play one the video stops but sound continues and the ui becomes laggy.
Better to get a HPH NT-V8, Tronsmart R68, Himedia H8 or Zidoo X6 with support.
That's what you get by using a no-name RK3368 tv box with no support.
http://chinagadgetsreviews.blogspot....op-511_21.html
The above firmware update has fixed all my issues including Netflix, Kodi, and audio.
There are currently 2184 users online. 0 members and 2184 guests.
