No, power management is embedded in Wasser's kernel. Flashing his resource won't do it for you. But the later RKM kernels also work well with power-off apps so the 902II Beta may be ok in that respect. BUT as I recall, that beta isn't rooted. Do you have a usb keyboard or airmouse you can use in the interim to root it? If yes, then use this package to root the RKM rom after you flash it.
Download and extract the two files. Place the supersu zip file on your external sd card. Connect the device and flash the TWRP (recovery) img with android tool (uncheck everything except recovery, navigate to where you put the recovery img and flash that only). Use reboot to recovery to boot into TWRP and install the supersu zip from your sd card. That's it.
After that, you can use a root explorer to copy the remote conf file that you took from Wasser's rom to System/Etc.
