MXQ OTT S805 Box Bricked- Red LED constantly ON
okay the photos have been re-uploaded.
THE ONLY WAY I was successful in having the PC detect the box in USB Burning Tool was to join the two pins on the nand.
Because it is almost impossible for a human to solder two wires on these small pins, I strongly suggest you trace the
pins to another component on the board using an ohm meter.
I installed a push switch permanently. This way I never need to open the box again.
Please be sure you know what you are doing.
If your board is NOT the same as the one in the picture I would not recommend you try this.
DO SO AT YOUR OWN RISK!!!
Originally posted by ckeays View PostHere are some more photos showing the serial connection and my alternate connections for joining the two pins on the nand. I had to glue the very thin wires down so they would not rip the tracks off the board!
Originally posted by Shadi86 View PostAnyone?
Download Tools
Make SDCard with tools and u-boot.bin in folder burnBootCard
Copy allfile in folder brick to sdcard
Copy all Firmware file to sdcard
open box, see the picture
1- unplug power, put sd card to box
2 - use clip connect 2 pin 7&8 see the picture
3 - when screen appear, release 2 pin, hold reset buttom
wait for upgrading
you can change the Firmware with correct firmware you use before
Good luck
Originally posted by vvd214 View PostDownload Firmware
Download Tools
wait for upgrading
Good luck
Thank you. Saved my device.
Ok guys, I am hoping one of you can help me out. I have a OTT MXQ box. The board is stamped "S805_MXQ_V.2.1_150516". I have shorted pins 17/18 on the NAND chip and can get USB Burning Tool to recognize it. I have tried to load the recovery image from 20150129.rar, the rom image from MXQ_110k4_20150325.img and the AML_upgrade_package from S805-1023.rar. No joy on any of these. All of them fail/error/timeout around 3-4%. I really need to get this box fixed.
Please help. THanks in advance
Originally posted by Spawn12336 View PostOk guys, I am hoping one of you can help me out. I have a OTT MXQ box. The board is stamped "S805_MXQ_V.2.1_150516". I have shorted pins 17/18 on the NAND chip and can get USB Burning Tool to recognize it. I have tried to load the recovery image from 20150129.rar, the rom image from MXQ_110k4_20150325.img and the AML_upgrade_package from S805-1023.rar. No joy on any of these. All of them fail/error/timeout around 3-4%. I really need to get this box fixed.
Download Tools
1. Make SD card
using Tool BootcardMaker.exe
Copy u-boot.bin and aml_sdc_burn.ini to SD CARD
Extract HD18Q_08232014_1007.rar to IMG file and rename it to aml_upgrade_package.img and copy to SDCARD
2. Unbrick
- unplug power, put sdcard
- hold reset buttom, plug power wait for screen appear, release power after 10s more
Done.
okay here is a more detailed picture.
The reason I chose these pads to connect the wires is because it is almost impossible to
solder to the nand pins without bridging two pins together. I used an ohm meter to verify that these two pads
are actually connected to the correct pins on the nand. Your board/nand may be different!!
The reason for the hot glue on the wire is to prevent the wire from detaching from the board,
(in case the wire is pulled) and possibly lifting the pad off the board, rendering the board useless!
The pad is very small and the solder does not hold very strongly.
The two connections are joined to a momentary push switch. This switch when pushed, joins the two wires together
until you let go of the switch. Hold the switch in until you hear the USB detect sound from your computer.
I mounted the switch on the LH side of the box so I can use it another time if needed (see picture).
Remember I am not responsible if you destroy your board!!!
If your board is not 100% like the picture then don't do this!!!You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by ckeays; 02 January 2016, 15:25.
if it fails after a certain time then it's probably your usb port (or windows saving power by disconnecting port)
there is a solution somewhere, do some googling.
I have had good luck with Windows XP. Anything else gave me a headache (windows 7, windows 8, etc)
Remember the importance of installing the switch!!
If it doesn't work, you need to try again so you don't want to have to solder wires to the very small pads
more than one time because the pads on the boards will lift, rendering your board useless!!
The pins only need to be joined until the computer (or usb burning tool) detects the board.
After that it should program, and your board is fixed.Last edited by ckeays; 02 January 2016, 15:38.
There are currently 2391 users online. 1 members and 2390 guests.
