MXQ OTT S805 Box Bricked- Red LED constantly ON
Originally posted by Shadi86 View Post
I took force and normal erase in setting, but are you sure you get the same fail message?
Try here for more help
http://mbox.co.za/forum/viewtopic.ph...t=182&start=10
My board is V03 anyway but maybe your board is v02, maybe you need different image i dont know.
Originally posted by Shadi86 View PostI have v2, but I give it one more try and see with a other img, I appreciate your help mate
Skickat från min D6603 via Tapatalk
These are the others i would try
If they dont work either then sorry, i dont know what to suggest
H MAn
Originally posted by gcsuri View PostOk, I found the recovery button in SPDIF
SDcard method haven't worked
Do I need to short the pins and push the button together???
If you cannot boot recovery from SD Card you will need to use usb burning tool and flash with the correct .iso. I have a V03 board. If you open your box you will see some print on the mainboard which will give you the version number. You will need to use a male to male usb cable. I made one up myself from 2 old usb cables and it worked a treat. No need to connect the power supply, just connect the 2 correct pins together with a small philips screwdriver, plug the cable into the otg port at back of box, as soon and you hear your pc connect to the box. remove screwdriver from your 2 pins. i think the 2 pins could be different depending which board you have, mine is a v03 and the pins i have to connect are pin 17 and 18 or ALE to WE. Hope you get it sorted, let me know if you need any more help
H MAn
Hi Hercules,
it's not worked. I used https://cloud.mail.ru/public/7oSn/WunL7sMWW - worked fine. Thanks.
gcsuri
Originally posted by gcsuri View PostHi Hercules,
it's not worked. I used https://cloud.mail.ru/public/7oSn/WunL7sMWW - worked fine T.hanks.
gcsuri
Glad to hear you have had a result, I'm wondering how Shadi86 got on as he hasn't said anything.
H MAn
Welcome everyone, I'm new here. my mbox does not turn on. By shorting pin 17 & 18 computer detects MXQ. on the motherboard I have such signs HD180_V1.2 2015/05/09 and S805-V1.2 20150520.
Please help which firmware I write it using a USB burning tool? I would love to go back to the factory firmware. in another forum someone had the same motherboard and gave a link to this rom "mxq_1207_aml_upgrade_package. img" file is 949MB. whether it is better to write it MXQ112k4. the latter worked with me or to load with the SD.
Or maybe something completely different, help rescue my box.
Originally posted by Piecia1980 View PostWelcome everyone, I'm new here. my mbox does not turn on. By shorting pin 17 & 18 computer detects MXQ. on the motherboard I have such signs HD180_V1.2 2015/05/09 and S805-V1.2 20150520.
There are currently 3390 users online. 4 members and 3386 guests.
