Image-UT3_220 r28patch
[QUOTE=heiko123;n525714]Hello,
I updated my r28 meta with this firmware, but I only see the start logo "uggoos" all the time.
What can I do?
Gesendet von meinem SM-P905 mit Tapatalk 2
[/QUOTE/]
I did this and the Parameter file was too large for my R28 Pro. You need to use the 4 GB or 6GB parameter file in Rockchip Tool. Follow the instruction Read Me in the Firmware files. My R28 is very stable and fast the best rom so far.
2.2.1 is working very well !
where i can find the partition enlarge option in twrp ?Last edited by gd350turbo; 16 December 2015, 23:47.
Just flashed 2.2.1b with boot.img from 1st post.
There is less micro stutters, but when the box get stucked after some time.
This is dmesg log:
Code:<6>[ 843.586238] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 846.097047] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 849.606824] rk_fb_set_win_buffer: Could not import handle: -9 <6>[ 852.524997] rk_fb_set_win_buffer: Could not import handle: -9 <6>[ 853.983292] rk_fb_set_win_buffer: Could not import handle: -9 <6>[ 854.542246] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 855.986403] rk_fb_set_win_buffer: Could not import handle: -22 <4>[ 856.645470] hdmi_dev_config_aai channel: 2 <6>[ 857.297488] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 858.134467] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 859.299127] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 859.314057] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 859.870884] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 862.878361] rk_fb_set_win_buffer: Could not import handle: -9 <6>[ 863.630432] rk_fb_set_win_buffer: Could not import handle: -9 <6>[ 865.202147] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 867.253583] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 869.236051] rk_fb_set_win_buffer: Could not import handle: -9 <6>[ 871.126067] rk_fb_set_win_buffer: Could not import handle: -9 <6>[ 886.881640] rk_fb_set_win_buffer: Could not import handle: -9 <6>[ 910.089714] rk_fb_set_win_buffer: Could not import handle: -22 <6>[ 911.090222] rk_fb_set_win_buffer: Could not import handle: -22
There are currently 1632 users online. 0 members and 1632 guests.
