MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1
Re: NEW - MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1
Originally posted by ves View PostHello, when active wifi internal system crashes and you can not recover the system anymore.
And try to run the stick with your keyboard or mouse only attached, withot external sdcard or hard disks attached.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Information from testing Finles 2.1, WiFi on 1.7c much stronger than the 2.1, but because 2.1 fluid works, some apps do not work yet with 4.2.2, XBMC works better on a 1.7 c for now, 2.1 is very fast, good software, with little processing it will be the best ... 1.7c tested and fast, a good alternative upto finishing 2.1.
This is just my opinion, not a criticism ... that amount with the respect for the hard labor of others on this great software ...
Originally posted by gor View PostInformation from testing Finles 2.1, WiFi on 1.7c much stronger than the 2.1, but because 2.1 fluid works, some apps do not work yet with 4.2.2, XBMC works better on a 1.7 c for now, 2.1 is very fast, good software, with little processing it will be the best ... 1.7c tested and fast, a good alternative upto finishing 2.1.
I think the same 4.1 is faster than 4.2 actually, but this 4.2 is a way better than the old beta.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Problems with localisation services.
Localisation services not work in my 808. More than once I turn it on and off, agree with google terms, turn on and off gps button. No success. Then I cannot use my current localisation in weather apps - WeatherPro and AccuWeather.
In 1.7c these worked well . Has anyone else this problem ?
Originally posted by Luko69 View PostLocalisation services not work in my 808. More than once I turn it on and off, agree with google terms, turn on and off gps button. No success. Then I cannot use my current localisation in weather apps - WeatherPro and AccuWeather.
After one day running, everything is perfect. Only “bug” I could see is; sometimes volume bar comes up while watching a video in OEM video player. It appears for one second and goes away again, it randomly pops up again.
Thanks for your efforts again Rob
What app do you guys use to test internet speed? On my phones I use the speedtest.net app but it won’t install on my MK808
Hi Bob,
When using the 1080.imgs, the Home screen is Fullscreen. But the Apps screen are not Fullscreen. They got like black borders on the right and left sides.
Is this how it should be?
I already reflashed to 720.imgs so can't take any photos of what i mean to show you.
One more thing, sometimes when starting up to home screen a pop up message say system process issue and let me choose to wait or end it. This happened the day after i flashed this new rom. On the day of flashing it did not happen. Once the nand was not mounted after it happened. Any idea why it is like this?
Originally posted by neoal View PostIf it was for you dont make it bad for the others too.
But i did not blame anyone. I know I decided to try it and is responsible. NOT Bob or anyone else.
Now mine is still not working 100% and i am also having problem restoring to stock rom.
BUT I am learning alot from here.
So here is a BIG THANK YOU to Bob and Leolas too.
RKRemoteControl is really nice to use if you get use to it But for some reason it crashes on Samsung Galaxys S4 but works good on my sons and wife’s S2 both are stable, when it crashes on S4 the phone won’t respond to anything for a while.
Does anyone else have this issue?
If this is off topic sorry about that.
I have some questions about the multi-user support:
- Can I somehow access to the lock screen settings to set up lock screen? I can't find it from settings.
- Can I somehow 'lock' device and change user? I think that one way should be via quick settings menu, but I could not figure how to access it. I tried some apps that "locks system", but those also 'turned off' display output and i didn't figured out how I can wake it up again.
And another question: I can somehow change usb-keyboard layout to non-US?
Originally posted by Sigismundpower View PostI apologize, it was a bad day!
Be sure that everyone have a bad day sometimes, I usually have them when people ask again and again the same questions, but, we must try to keep calm, count from 1 to 10 and then when we ask.
For my side, no problems with you , but please before post something try to keep calm the next time.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by Lamelogin View PostI have some questions about the multi-user support:
Originally posted by Spawn View PostRKRemoteControl is really nice to use if you get use to it But for some reason it crashes on Samsung Galaxys S4 but works good on my sons and wife’s S2 both are stable, when it crashes on S4 the phone won’t respond to anything for a while.
One more thing, sometimes when starting up to home screen a pop up message say system process issue and let me choose to wait or end it. This happened the day after i flashed this new rom. On the day of flashing it did not happen. Once the nand was not mounted after it happened. Any idea why it is like this?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2403 users online. 5 members and 2398 guests.
