MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1
Originally posted by Spawn View PostThanks for your answer leolasYes Galaxy S4 is 4.2.2, I have to wait a little for a update I guess. Since the other two phones will be upgraded to S4 soon, it will be nice if it worked.
REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
The 1080 kernel is nothing more than a patched 720 stock kernel.
1080 performance will never be as good as the 720 kernel. There is more data to write to the screen now.
I simply made the 1080 kernel because I could and some people want it
Personally I use the 720 for best performance. I really do not see much of a difference in videos between 1080 and 720 so for me I go for the better performance of 720.
@leolas, I will check those thanks.
Originally posted by debay View Post
Does it work with the 720p Kernel? Does anyone know this?
Originally posted by Finless View PostThe 1080 kernel is nothing more than a patched 720 stock kernel.
Hi Bob,
Thanks for the rom, by far the most stable and capable rom for me. I was able to stream a 1080p MKV movie over the wireless without stutter. I maxed out to my Internet max @ 40mbit/s on speedtest over N wireless, which is something I could not do earlier.
I noticed that the device physically overheats after 10 minutes of watching the full HD movie. This causes stuttering and dropped frames. I had to crack the cover open to improve ventilation and put a fan blowing towards the device to finish watching the movie - this solved the heating problem.
Thanks to mopp as well for instructions on how to get "all" apps visible in Play store with the buildprops and xml files.
/John
FYI the kernel is somewhat unlocked.
I have tested and you can overclock it to 1.5. It wont report to set CPU that it is running any faster (something is wrong with how it reports) but in fact when you overclock it you can see the results in linpack increase.
See this thread starting at post #29
Originally posted by Sigismundpower View PostI have noticed my device does not boot the original adapter, usb only general voltage. I've never seen it! The installation allows only 1 GB of transfer are released when you run out, such as mobile phones. Others have also checked in?
@hknklbl like Finless say, seems that this rom haven´t the clock locked like the ones released before, the people who have problems with this rom, have the stock power supply?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by hknklbk View PostHi there, I installed this one, but when I open WiFi switch, the device starts rebooting. Nothing was connected, even the same result. So I revert back to another rom.
The overall performance seems to be better with that kernel, so i will stick to that!
problem with that version 4.2.2
I do not know what to do to solve the problem with that version 4.2.2 has tested several more crashes when I turn on wifi and everything back to the home screen and is deleting and back all the time.
My TV box is MK808 RK901 someone help me?
Thank you.
: Rosto
There are currently 2660 users online. 0 members and 2660 guests.
