MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1
Originally posted by richardg1952 View PostI find 2.1 has better performance especially for DLNA...but there is the scrambled Netflix that is not an issue on 1.7. I use DLNA more than Netflix so I made the trade off. Or course, I want bothLast edited by iHero96; 13 August 2013, 00:24.
Originally posted by iHero96 View PostYes this too, Netflix is one of the reason for these things to exist, but i found this on Geekbuying with Netflix fix on Android 4.2
Originally posted by dav_id View PostCan anyone confirm Logitech c270 webcam work on this Rom?
Thinking to get one....
__________________________
Sent from Galaxy Note II (GT-N7100) using Tapatalk
How to Mount Internal SD?
Everytime I try to download something with the web browser I get a error that the SD card is not pressent or mounted.. I also get the same error when opening the music app. I have a SD card inserted and it is mounted as external SD, I need the Internal SD mounted...... Help please.
Re: NEW - MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1
Originally posted by dleric View PostEverytime I try to download something with the web browser I get a error that the SD card is not pressent or mounted.. I also get the same error when opening the music app. I have a SD card inserted and it is mounted as external SD, I need the Internal SD mounted...... Help please.
Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
Very Nice Rom for 4.2.2.. butmiss tun.ko module on kernel
Hi guys, i have flash on my mk808 original this nice rom it's very good! but..... i must return to 1.7c because i need a tun.ko module load on kerneli hope the next release you can add on this module.
I have try the apk Tun on google play i can load on the fly a module but openvpn server freezethe only way is have a module loaded on kernel.
Thanksss Guys! (sorry for my bad english :P)
lollo from italy
Likely busy and lets face it the older devices quickly loose support because interest shifts to the new devices.
Look how quickly the makers drop support for their older hardware.
Its likely not dead in here but don't expect it to be as quick as before in the development end.Mk802IV Neomode 1.9a original rom 720p
Thank you Bob to this ROM. I flashed this last Friday on a brand new original MK808B. It came with 4.2.2. I had to use the reset button to get the device into flags mode.
I had an issue with the 1080 kernel, but I let the unit settle and it worked fine.
My computer monitor has an HDMI port but apparently does not run 1080P. So I had to configure in on a TV.
FWI I loaded Droid VNC Server https://play.google.com/store/apps/d...aips.vnc&hl=en
So you can configure it remotely.
Sent from my Nexus 7 using Tapatalk 4
There are currently 3242 users online. 0 members and 3242 guests.
