Thanks!
MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1
do these kernels work with this rom?http://www.freaktab.com/showthread.p...rnels-Released
I attempted to install this kernel with this rom at the same time on the mk808, previously it had the firmware shipped from the factory, for the install kernels, it said not to erase idb but this rom says to erase it, was i not supposed to install both at the same time? the first time it flashed fine but when it rebooted it just said unsupported format and turned off, then i tried to reflash but when checking the install it would fail, i think i got it to flash again with a 720p kernel from the overclocked kernel and the 1.7c finless rom when it rebooted recovery just popped up and said formatting data and didn't go beyond that point. does anyone have any insight?
Originally posted by phinc View PostFlash any rom with its original kernel. Always erase idb before flashing a new rom.
Sent from my GT-I9100 using TapatalkLast edited by Ry024; 17 January 2014, 15:30.
Originally posted by phinc View PostErase idb, flash the entire rom with stock kernel, see if it boots, then try to flash the patched kernels without erasing idb.
Originally posted by flynreelow View PostBeen out of the game for a while, but looks like this is going to be a killer rom.
What did we find out about Dolby digital and DTS passthrough though HDMI?
Possible, not possible, in the works?
LMK
camera usb don't work
He,
I'm nob on TV stick.
I've heard that the logitech HD C270 works well with MK808. I've specially bouth one for this.
But it doesn't work.
USB camera test app says disconnected even when connected to OTG port or to a powered usb switch.
Is there a solution to make it work ?
Thanks for replay
TV doesn't support format
Originally posted by Finless View PostI wish I know why this is true on 4.2.2
This is something that needs to be fixed by ALL TV stick makers or the amount of returned products will grow leaps and bounds as 4.2.2 becomes the standard ROM these ship with.
It might be something with EDID setting interlaced or progressive output?
It might be some format change that some TV cant support?
Other possibilities why?
Someone with TV equipment that can analyze the output needs to look at this. I am sure it can be fixed but until we know what it is, it's a guessing game!
Only thing I might ask you guys with this problem is try playing with your TV settings. Also if you have a HDMI switch or something, try going through that. Some of them may normalize the signals.
Any suggestions?
Thanks.
Originally posted by Dave-s View PostBought the MK808 from geekbuying with 4.2.2 already stock. When I plugged it in with the stock ROM, it booted up no problem. I tried flashing this ROM to removed all the bloatware with 720p or 1080p kernel/boot, and both were not supported by the TV.
Any suggestions?
Thanks.
May we know the manufacturer and resolution of your TV ?
losl
The Finless 2.1 ROM defaults to 1080p display (even when you flash the 720p files).
Thus you need to boot on a TV that will handle 1080p display. Accomplish that, and you can change to 720p in settings and then go back to your TV and it will likely work.
Suspect your older TV only supports 720p.
There are currently 2314 users online. 3 members and 2311 guests.
