Also, try another TV.......
MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1
Originally posted by jay.braxmaier View PostHello,
I tried to download the Finless 2.1 rom from the link at the beginning of this thread, but it doesn't work. Is there a link I can use to download it?
Jay
Here is a link to Finless 1.7 for MK808 - https://disk.yandex.com/public/?hash...vyvWzH6yJ/s%3D
Originally posted by mo123 View Post'The Finless ROM's were deleted by a disgruntled dev that got kicked out for dishonesty and their attitude... it will take some time before they get restored' from rdsok. Here is a link to Finless 1.7 for MK808 - https://disk.yandex.com/public/?hash...vyvWzH6yJ/s%3D
I am uploading all my MK808 ROMs now. They should be working in the next hour or so.
Originally posted by Warlord1981 View Postguyz which is the most stable and faster XBMC release for this ROM and device for playing HD content?
Thank you
I really like Beyond XBMC just about no matter the ROM http://www.freaktab.com/showthread.p...BMC-(Beta-3-3)
I usually have no issues with the built in player... which may indicate it is your internet connection or type of network connection at fault. I typically see little if any difference using say MX player instead. Try testing with a local file to prove if the issue is your connection... you can also test your internet connection itself ( if that is what you are using ) with any of the several tests available on the play store.
I know I can't do anything about what hardware you have chosen to use as a controller...
Originally posted by rdsok View PostI usually have no issues with the built in player... which may indicate it is your internet connection or type of network connection at fault. I typically see little if any difference using say MX player instead. Try testing with a local file to prove if the issue is your connection... you can also test your internet connection itself ( if that is what you are using ) with any of the several tests available on the play store.
Originally posted by Warlord1981 View Posti tried playing over network from my samba shares and it plays 1080p smoothly. streaming on the other hand was not bad but it had sone stutterings in scenes with motion. i have 6mbps cable connection.
There are currently 1445 users online. 0 members and 1445 guests.
