Sent from my Moto G using Tapatalk
MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1
Problem Problem Problem
Hi threre!
I have a Rickomagic mk808 (w/o B) with finless 1.7.
I just tried to flash this ROM. But failed to introduce the device to my Windows7(64) system. Than I realized I must turn off USB debugging and turn on the "PC Mode". I did so and plugged the mk again to the pc. Still nothing happens. The mk gets only power (blue led) but this is it. Even no "unknown device" message. Than I thought the mk808 is might not in USB mass storage mode. So I plugged it off the pc and back into the tv to controll this, but....
I have now a boot loop with finless' psychodelic boot image. The mk808 fails to start up android. Is it because i toggeled it into "pc mode" since the last start?
What can I do now?
Appreciate your helps, thank you!
Edit: Ok i used the Hardreset-Method as described in thr read me file
Thanks finless!
Brick @ Finless 2.1
Hi folks,
my MK808-non B was running quite fine @ Finless 2.1 (except of the wifi problems). A few days ago it reseted itself and now it stucks on the boot screen. My PC does not recognize the stick anymore so I cannot reflash the ROM. Is there another way to unbrick except of the NAND-PIN method (which sounds unsafe).
Thank you in advance...
I have tried to do a "hard reset" to wipe all the user data. Like explained here: https://www.youtube.com/watch?v=FWM0P0SFAJ0
Wiping works, but the system stucks on boot again.
So I get into recoverymode... could I fix it by using an SD card and reinstall Finless 2.1 directly in the recovery?
Originally posted by k-Rize View PostDoes anybody have the remote app that comes with this Rom and installed in the storage folder, I need a copy plz?
Sent from my XT1031 using Tapatalk 2
BT dongle compatible
hello folks,
This is my first interaction here (i just registered), but i aways come here to search for info about mk808.
Im sorry for my unknowledge, but i realy serched for the answer to the question im going to ask here, but didnt find a solid info:
Is this rom (MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1) compatible with usb bluetooth dongles? i would like to add bluetooth to my mk808 (non B) device...
many thanks in advance!
Re: MK808 Non-B JB 4.2.2 Official - Finless ROM 2.1
There are currently 1678 users online. 1 members and 1677 guests.
