This is my first time posting and this is my situation:
I've got a generic TV Stick with RK3066. It was working perfectly until I did something stupid. I've wanted to test some tweaking in the build.prop file so I've made a backup copy of the original file, did the modifications and rebooted the unit. Everything went just fine and the stick worked normally. Then, as the tweaking in the build.prop file didn't make the desired effect I've decided to restore the original file. So, changed the name of the modified file (so I can keep it just in case) and restored the previously backed one. Since the next reboot it stopped working. It only shows the Android boot logo and then it gets stuck in the loading animation.
Sadly I think It will be very hard to restore it as I can not go into recovery or flash mode (it doesn't have any hardware button, neither a reset one) and I don't have the original firmware anyway. The PC (Win 8) doesn't detect the unit at all. I just see a "restore" legend in he PCB where maybe it should be the reset but I'm not sure.
I post some pictures of the board. Any help would be very much appreciated. And, please, sorry about my english.
Thanks in advance!!
