I have recently bought a Vigica C100S set top box for its ability to run DVB-S and Kodi. Unfortunately after scanning for channels i have alot of duplicates and the order is completely random. It does have a built in channel manager that lets you sort A-Z, move and delete channels but this is very time consuming.
I am hoping that someone has already set up their box and has a backup of their dtv settings including channel list so i could restore them onto my box.
Failing this I would like to install some kind of linux OS and use enigma2 or similar with easily obtainable channel lists but this has to be a last resort or a simple step by step instructions link. Openelec with TVHeadend seems to be an option but i have read that it disables wifi on the c90s and can't find any clarification on the c100s either way and don't like the idea of wiring my house up with ethernet cables.
Do any of you use the Vigica c100s and if so what setup are you using?
