as even when i tried the file with the swopped over header it still said "restore user data success" were we know it to have an incorrect checksum, so kinda confirms it all...
yeah the file im using (with header i posted with blank checksum (4...7) to test my system/scrip/python is a raw/blind scan on box so all working, then the single dvb_s_mw_s1 transfered to pc,
decomposed, then just renamed the all_services to match the one listed in my compose.py, and composed it again ! transfered back to box.....
like i say just to test it all ! ..... Once i get that going, will use my already days worth edited/changed file/channel folders ! etc...
just doing it this way to narrow down my problem,
of which im now 99% sure its that checksum at 4---7.... but posted all my workings along the way by editing my original post, so it may help others, and to show where i was/had tried !
will try on a fid PC, entill i get that checksum sorted !if not will work out how to try manually calculate it in a hex editor ! .. i presume its a crc-32-mpeg checksum of location 8 to end of file ?
cheers again for replys
its a great start, no idea how you figure these things out from scrath ! i cannot even get it working when i know how its supposed to be !
