Stable ROM for MXV S805
    Hi. I've this BoxTV, too.
    I wrongly installed OpenElec for MXQ and now the Box doesn't boot.
    Now I try to burn the ROM that is in this topic but wont burn.
    I use USB_burning_Tool and I received an error "Close device handle 0x0000027c".
      Hello Guy,
      I haven't any usb2.0/usb2.0 cable with my box... How can update .img rom without that?
      Can i use an app to to that?
      Thanks.
        Originally posted by roolmapool View Post
        Hello Guy,
        Thanks.
        A male/male cable is really cheap and will make you the process way more easy, just try not to buy any of those absurdly long ones ( >2 meters), the USB signal is pretty weak and can give you some errors in the flashing process. Also if you can't find any shop with them you can grab a couple of old USB cables, cut them and solder their cables matching their colors, it's pretty easy.
          Thx... i just buy one
          I ll flash soon....
          Can i find a openelec rom with this device? maybe tv110 firmware is compatible....?
          Regards.
            Hello, did you find a fix for the delayed Bluetooth audio?
              Yes - what I found is there is no lag when I play videos using default video player. But when I use MX Player or Kodi or VLC then there is audio video out of sync issue. Hence its not really bluetooth issue but video player issue.
                Found new version of the rom. Updated first post with the link.
                百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
                  Hello, is this newer and better than;
                  What are the Pros and Cons between the two? Thx
                    I think both ROMs have same source.
                    From other thread:
                    10- Your system will now be upgraded with Build number KOT49H.20151119-1617, and probably now all future updates may be performed online.
                    Most likely the rom that I posted is the one that you will get after updating the rom posted in other thread. Hence if you want latest rom in one go then take the link from my thread
                      Where do the future online updates come from? Are they right from the manufacturer?
                        Not necessarily. Enjoy your device friend without getting too much into it. Use any rom or try multiple roms and decide by yourself the best one that suits your needs.
                          not too sure HOW i download this. I dont speak mandarin.
                          Can someone re-host it? I saw the link to the other thread(vensmile one) but the file is ~60megs smaller, and thus not the same rom.
                            mystguy
                            Do you know if both 1023 and 1119 have the random mac address problem?
                            Do you know any rom that doesn't have this problem?
                              kiodo1981
                              1- Don't use VM (Parallels, VMware, etc) to burn the firmware
                              2- Don't use desktop frontal USB ports (internally wired)
                              3- Try changing the computer USB port (MXV's must be port 4)
                                For anyone looking to buy the MXV, Gearbest has them briefly on sale for $29.99. There were about 100 left at that price last I checked.
                                Note: Not a recommendation for the device or seller, one way or the other. Just a heads up.
