( resolved ) please help me with problems mk809iii
    I have a dongle mk809iii rk 3188Tv5_2 20141115 I can not flash error download idb failed
    I do not know what to do you can help
    I'm trying to install [ROM][4.4.2] REAL 1080P on CYX_809III V5_2 20141105 MK809III RTL8723BS with neonmode rom flash tool 1.37
      Memory has corrupted or failed. You can short the pins, it may take two people or one four armed person, just place a needle between 7-8 or 8-9 in the memory (2nd pic, just beneath the green part) not sure which end...and while also pressing reset plug into usb...This will get you mask rom mode and you may be able to flash from that.
      Currently Inactive on Freaktab.com
      I use: MK903V | MELE F10 Deluxe | Roku 3600R
      RIP: MK808b | MK809III | PIPO M9 Pro
        I have to count the pin from the left or right ?
          I don't own this device, but the "dot" on a chip usually indicates pin 1.
            free image upload
              I'm stuck at this point . It does not move
                if the problem is at nand , I can only use the micro sd ?
                  It looks like you pressed the "restore" button, isn't pressing "upgrade" the usual method?
                    Reset boton + 7-8 pin.
                    something wrong?
                      something wrong?
                      I was referring to the software buttons in the RK Batch tool.
                        ah ok , upgrade
                          ah ok , upgrade
                          Again, I don't own this device and I usually use the Android Tool to flash my 3288 box. I'm not very experienced on the 3188, but I think the "upgrade" software button is the right one.
                          Good luck.
                            It exists for windows . you have a link to download
                              It is a Windows tool. I don't know if it is suitable for the 3188. I don't know that it isn't either. I just don't want to give you wrong advice.
                              The batch tool you are using should probably work.
                              The Android Tool is usually included in the update packages for my box and others. I'm sure it can be downloaded from somewhere, I just don't know where right now. I am posting this on my phone and searches from it can be tedious. I will post tonight when I get to my PC.
                              Good day.
