Got to get some sleep now. I'll check back in tonight and see if you have had any luck.
( resolved ) please help me with problems mk809iii
My dongle is very similar in hardware , but does not have the antene and has the phrase CYX
I have this
http://it.aliexpress.com/item/Free-S...pNumber=826335
I tried installing this firmwre
installation okay
I went into Android desktop
but I will go out and reboots itself when using
I asked the seller of them give me the link to download the original firmware , but also with the original I was dying when I used kodi
maybe he warming too
It's not rebooting because of heat. It may be the power. Try a different 5v2a plug and a different usb with it. Don't plug into the tv.
If you used the firmware from the other thread that I linked to and it all works fine, the reboot must be coming from the power.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
budgetgeek has experience with these, as I have said, I don't have much experience on the 3188. Since he doesn't think its overheating, I'd try his suggestions regarding the power supply.
I have a 3188 box, it has a heatsink and can get pretty warm, I don't see how they keep the sticks cool without one. Aim a table fan at the stick, to rule out heat as the problem.
Power supplies have been an issue for many of these devices, so it would not surprise me to find it was your sticks issue.
Keep us posted.
Originally posted by evi83 View Posta power supply for smartphones can be fine ?
And you may be able to fit a small heatsink in the casing, I took one off my mk808b and fitted it in but I haven't recovered from the prepare idb failed problem yet.Currently Inactive on Freaktab.com
There are currently 4916 users online. 0 members and 4916 guests.
