New MK809IV - X3_V30 20150805?. Help!!
I have try this one "cyxtech_rk31_809iii_8723bs_141111_4.4_8g2g.ra r" but now my stick is bricked, complete dead.
I have try to unbrick it on the way in the link, http://freaktab.com/forum/tv-player-...d-on-the-mk808 , but there is a different IC, I try pin 8 and 9 and 7 with 8, but now waySub Forum for Rikomagic TV sticksLast edited by Holleman.t; 19 November 2015, 11:17.
huh.
this is kernel for fake cx-919 (aka tronsmart 809iv) in next configuration:
RK3188T + RTL8723bs + BlueTooth
wifi work is ok, bluetooth work with rtl8723bs_bt toolkit at ttyS0 device
get sdcard linux image from http://build.radxa.com/rabian/nightl...51125/rockdev/ put it to sdcard
get image from http://aborche.com/files/boot.img.gz, unpack it by gunzip boot.img.gz and
put it with "dd if=boot.img of=/dev/<sdcarddev> conv=sync seek=16384 to sdcard
put card to stick and try to boot
when boot is ok, use login and pass: rock and rock for login to system
in /proc/config.gz you can find current config for this kernel
Please tell me a liitle more detailed way. Shoul I download "boot/boot-linux.img" or "rk_loader/sdboot_rk3188.img" Which one?
I downloaded "boot.img" but I didn't understand this part :
can you please explain it step by step? I'll be very pleased if you help me. thanks in advance.
huh.
CX-919 forked kernel from radxa-rbox. rk3188+rtl8723bs. rabian, ubuntu, linaro, kali - aborche/cx-919-radxa-rbox-linux-rockchip
This is my working kernel. This kernel forked from radxa kernel and optimized for RK3188T. Kernel source contains rtl8723bs driver version 4.3.12
if you not see any wifi devices after booting, just do it
echo 1 > /sys/class/rkwifi/driver
echo 1 > /sys/class/rfkill/rfkill0/state
and check your dmesg.
This is just kernel
this is kernel with initrd.
Originally posted by zhecka View Posthuh.
https://github.com/aborche/cx-919-ra...linux-rockchip
This is just kernel
First I installed a working rom WITHOUT wifi and bluetooth (CYX_809III V5_2 20141105 RTL8723BS RK3188 1080P),
Then I flashed the kernel file you sent (http://aborche.com/files/4pda/15-12-06/Image.gz). The result is boot loop between android robot and "no signal warning"
When I flashed the other file you sent (http://aborche.com/files/4pda/15-12-06/bootcx919.img.gz), the result is just black screen. no picture, no android robot, or no warning.
Do you have any idea?
There are currently 1931 users online. 0 members and 1931 guests.
