Amlogic MXQ M10 S812 Metal TV Box firmware/root
    Originally posted by tmwmad View Post
    HI Txemoto,
    Yea I tried that but had no success, it worked on previous boxes but not this one. I think the location on the box being coded into the rom being Shanghai is the problem.
    I didn't try the build.prop but this apk works.
    *** USE AT YOUR OWN RISK *** I’ll not take responsibility for anything happen to you or your account *** THIS APP IS FOR ROOTED DEVICES ONLY *** ( I’ll add some nice features for stock/non-ro…
      http://codekiem.com/2013/02/13/market-helper/
      yea I use that app too but i would love to know how to make it permanent.
        I found by editing this portion of build.prop the problems with playstore are sorted. remember to backup old prop just in case of problems.
        ro.product.model= Nexus 7
        ro.product.brand=Google
        ro.product.name=Nexus 7
        ro.product.device= Nexus 7
        ro.product.cpu.abi=armeabi-v7a
        ro.product.cpu.abi2=armeabi
        ro.product.manufacturer=Asus
        ro.product.locale.language=en
        ro.product.locale.region=US
        ro.wifi.channels=11
        ro.board.platform=meson8
        # ro.build.product is obsolete; use ro.product.device
        ro.build.product=M10
        # Do not try to parse ro.build.description or .fingerprint
        ro.build.characteristics=mbx
        # end build properties
        # from device/amlogic/M10/system.prop
          ro.wifi.channels=11
          Thanks for sharing.
          Mine's comes with a rom rooted dated in 20150610.
          Do you think that i must update with the firmware you posted before?
          I haven't seen the google play install problems. What are the apps you cant install?
            Originally posted by Txemoto View Post
            Thanks for sharing.
            Hi again, if you are able to install apps without any problems I would keep the firmware you have and leave it alone, my box was unable to install a lot of apps including Facebook and Google photos but thankfully sorted now.
              Ok, so I used this ROM/Firmware to update my M10. I DID NOT wipe date or media, once flashed I installed Super User from the play store and updated the binary when prompted and now I'm rooted.
              did flashing this firmware fix the playstore issues ?
                HI Txemoto,
                They should just code north america into the rom or tell us how to do it cause i would like 12h format clock
                  Hello!
                  Already on sale there M10 MXQ with firmware KOT49H.20151101.test-case.
                  Prompt a reference to this firmware.
                    I am trying to re ibstall firware, after a disaster!
                    Using the Amlogic burning tool.
                    Burn succsessful till 97% then it stops saying-
                    0x30702004 uboot/temperature testing/ gets results/ out of range
                    What can I do please ?
                      Problem solved by re setting the default temperature range at the VIEW tab to 20-60
                        Could some post the firmware for this unit
