In case of crash try to replicate it and, please, include logcat.
You can't use this launcher on the Play running WeTek OS because it requires at least Android 4.3 for the notification APIs but if you are using my CyanogenMOD build you can use it on the Play as well (but you might need to use a keyboard to access some of the functions since they are mapped for Core's remote).
Instructions
Download the zip file containing the apk, unzip it and install the apk using your preferred method (using adb install, copying it to a MicroSD card and installing it using a file manager, etc.)
As very first thing allow the launcher to access the notifications in "Settings -> More Settings -> Sound & Notification -> Notification access".
I have created this launcher for being light and very easy to use, in fact using the Core you will do most of the actions using the * (star) button (if you don't have the Core's remote you can achieve the same with F6 button on a keyboard).
In the top row you have the notifications, you can click with OK button on them to open them in a popup or you can dismiss the selected notification without opening it using * button.
In the second row you have the highlighted apps section, the middle icon is the app drawer. From the drawer you can add the selected app to the list of favourite apps (the third row in the home of the launcher) by pressing * button, you can also long press OK to access to the app information menu where you can uninstall/disable the app, clean the cache or data, move the app to the sd, etc.
The third row, as previously said, has a list of favourite apps. You can re-arrange them by long pressing with OK on one of them (you will see that the app rectangle has a blue border, meaning it's been selected), moving to the position where you wanna put that app and long press OK again to swap the two positions (it's easier done than said), if you long press with OK on the same selected app it will clear the selection.
To delete a favourite app use the usual * button.
The last row has three icons, one for the connectivity (showing if you're connected by ethernet, wifi, or not connected at all) that will launch network settings when clicked; one that will launch android settings and another one that shows the weather and, once clicked, will show a popup with a 5 days forecast (from this popup you can toggle C/F degrees by pressing, guess what? * button
Video
Download
1.2.1
Changes
1.2.1:
- Added option to hide applications
- Added support for icon themes (have a look here for more info)
- Added Turkish translation
20151126:
- A lot of improvements under the hoods, included fixing a FC when using IP geo location since the public API I was using is not available anymore.
20151104:
- Added the possibility of fetching weather for a custom location. You can access to settings by pressing menu button in the main launcher window
20151101:
- Added current temperature and current city to the weather icon in the footer
- LP only: modified the visual feedback of the currently focused highlighted/favourite app
20151030:
- Added the possibility of customizing the Highlighted apps (all but the app drawer). Long pressing on an highlighted app will bring up a dialog where you can choose the new highlighted app. To reset an highlighted app to the default state press the usual * button on the customized highlighted app.
If you are running one of the latest Core rom that have this new launcher as system launcher you won't be able to update unless you use this file.
20151029:
- Added a colored circular reveal animation in the home section when interacting with objects that launch something
