Gesendet von meinem Be Touch 2 mit Tapatalk
New launcher for WeTek Core
New version, check the op.
WeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
Added new version and a videoWeTek Play
Thank you for the video, you have created a fantastic launcher. I don't have one yet, but hoping the Easter bunny will put one in my Christmas stocking. You talked about tvheadend server running on your Wetek Core, does it also have the drivers included for the HDHomeRun tuners, like OpenELEC does? Right now I am using my MK808B Plus running OpenELEC and tvheadend for my PVR backend and it works flawlesslly. With the Wetek Core running Amlogic S812, I would imagine it is a demon, and I certainly want one.
Again, thank you for all your hard work.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I built all the USB tuners available on linux-media.git, do you have vendor id and product id of such tuner so I can check if it's supported?WeTek Play
Thank you
you can ignore/remote those marked "translatable=false"
WeTek Play
translate finish
Turkish Translate Strings
Waiting Impatiently
good job
Thanks, I will add it tomorrow morning
edit: new versionLast edited by ChristianTroy; 02 December 2015, 20:47.WeTek Play
Hi Christian,
I really apreciate your work and i'am using your launcher on my M8S box. Can you please add the possibility to customize this launcher shortcuts using a regular remote or airmouse?
I am using an airmouse and i cannot change my location from weather settings, neither add new app icons on main screen
Thank you!
There are currently 2222 users online. 1 members and 2221 guests.
