Beelink R68G Firmwares (Gigabit lan & WIFI AP6335)
Originally posted by tsukaza View Post
No, because the i68 uses the AP6330 wifi chipset instead of the AP6335 used by R68 on both Beelink and Tronsmart. So you will lose WiFi and blue tooth function.
I am using the latest beta from Tronsmart and both Wi-Fi and Bluetooth work on my AP6330 based i68. The only issue I have with the firmware so far is that it fails to come out of standby occasionally.
Is this the version of wesser ROM you are using. Thanks.
wasser-firmware-lollipop-3.1.2-i68-1000lan-rk3368
Originally posted by androidgadget11 View Post
I have a beelink i68G, how can I change/customize the Home appearence like that?
Thanks in advance
Originally posted by BewickPlace View PostI am using the Tronsmart beta L205 1203 not the wasser rom.
Good Luck
Tronsmart Orion R68G_205L_151110
http://chinagadgetsreviews.com/downl...-tv-box-5.html
Thanks.
Is it the R68 firmware version that I posted earlier for the Tronsmart R68 in the Tronsmart forum. Or a different firmware?
Thanks.
Beelink R68G with 205L1203 firmware
Antutu v6.0 score 38460
During the Antutu test, were big problems with audio (maybe here is the anchor point for our problems with stutters?)
For one moment, max power consumption 8.4W
Hello,
Just a quick note about firmware 205 Beelink and Tronsmart
in HDMI bitstream
DTS HD Master ok,
Dolby True HD ok,
DTS slowed his / deformed,
Dolby Digital slowed his/ deformed.
all with a small shift , when most offset bitstream is removed
but the sound becomes stereo and amp switches to movie mode.
Test performed with 720P and 1080P movies on amp Yamaha RX V465 et
Box i68G
Wifi ok
RJ45 ok
(Waiting in a functional firmware or functional Kodi I use my box mk808b + that works perfectly HDMI bitstream .)
Thank you for your work!
Good day everyone
I have the Beelink R68G 1000m and have been trying to update the firmware shown in first post.
The problem I am having is the box not being recognized by my computer. I have tried installing the drivers but to no avail. Could this be because I am running windows 10?Last edited by Altaman; 02-12-2016, 03:42.
I struggled in the same way under Windows 8.1. I then moved to a Windows 7 machine and it worked immediately. I therefore assume it is a driver issue.
There are currently 817 users online. 18 members and 799 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
