K1 PLUS Amlogic S905 4K KODI TV Box Android 5.1 1G/8G 2.4G WIFI LAN HDMI2.0 3D DLNA AirPlay Miracast
I have found this firmware update http://blog.geekbuying.com/index.php...ware-20151204/
Not sure if it fixes any of the above problems from other users.
My problem with the pink hue on certain times while watching on KODI or even a movie through the video player, I doubt it would be fixed. As I understood the TV BOX is sending out signal that the TV just doesn't like. No idea if it's something that can be fixed by an update.
Originally posted by pelloplasma View PostI have found this firmware update http://blog.geekbuying.com/index.php...ware-20151204/
Why would geekbuying state that as 1204 when its 1123 inside?
where exactly do people go to get the "Best of" or Latest news about apps and new firmware for android tv boxes, this is my first box and so far I'm not really sure what I'm doing and/or what I could be doing.Last edited by HyeVltg3; 14 January 2016, 01:45.
Where can you find the 11.28 firmware update? One site that supposedly had an update when you were downloading it, it was the 11.23 firmware instead.
Originally posted by treborRoot of the K1 Plus Amlogic S905 is possible using the Minix Neo ezroot.zip by Finless
Follow instructions mentioned and you will have root.
If not try the Minix root method
Boot from SD card,
My unit would not boot from card, could see files many formats did not resolve problem
As it could not find the recovery to get signature for ezroot.zip it failed
Finally I did boot from a SD card in USB card reader, I could then load from EXT from with in loader
Messy but worked.
Cheers
Sent from my SM-G900T using Tapatalk
I got last week the K1 PLUS. (20151128 ver)
My problems:
-Volume goes down 1 step randomly
-If the TV switched on after K1 PLUS, then it's says NOT SUPPORTED INPUT
-Kodi has some forceclose, but only if im browsing the movies.
I also found the 20151204 software, but nobody confirmed if it's new or 20151123 version.
Did anyone tried this update?
There are currently 1907 users online. 3 members and 1904 guests.
