K1 PLUS Amlogic S905 4K KODI TV Box Android 5.1 1G/8G 2.4G WIFI LAN HDMI2.0 3D DLNA AirPlay Miracast
    Originally posted by Gemilan View Post
    I got last week the K1 PLUS. (20151128 ver)
    My problems:
    -Volume goes down 1 step randomly
    -If the TV switched on after K1 PLUS, then it's says NOT SUPPORTED INPUT
    -Kodi has some forceclose, but only if im browsing the movies.
    I also found the 20151204 software, but nobody confirmed if it's new or 20151123 version.
    Did anyone tried this update?
    Sell it or return the tv box while you still can and get one from a company that provides support and firmware updates.
    It will save you a lot of trouble in the feature.
    Eny boxes are known for having firmware problems and no updates provide actual fixes.
      Could You recommend a device with same specs,for 42$ and good support??
      Thank You in advance!
        You can wait for the RK3229 devices to come out. Will come out in the next 1-2 months.
        They will support all the latest codecs like VP9 for 4K Youtube decoding, 10-bit X264/X265 and over 200mbps bitrate playback for videos.
        They will be the cheapest option for around $50-70.
        At the moment the only decent Android boxes cost between $100-$150.
          Originally posted by mulderfox
          I am using the Videostrong KI Plus with DVB-S2/T2 (S905 based) version, and I'm experiencing crashes from Kodi. It seems to have to do with multitasking issues - when the box is overwhelmed it simply crashes out of Kodi. Anyone knows when there will be a firmware update?
          Thanks!
          You have the latest KI plus S905+T2+S2?
          If you have it,send me your firmware version.
          Check cpu temp via Cpu-Z app.
          When you start the box,not use Kodi,just use youtube or some other app,just to see if system will crash.I think there is no problem with Kodi ,but problem with system stability.
          Sent from my HUAWEI MT7-TL10 using Tapatalk
          Free 100Gb space for your files:
          https://degoo.com/g/Ov7nAz0
            Please check Cpu tem via Cpu-z app,just to compare it with my box.
            When you said thet DTV is rock solid you mean for T2 or S2 part?
            For me T2 is rock solid ,but S2 have some problems like black screen from time to time or cccamd freezing.
            Did you test how cccamd works?
              Send me all part from Bulid number(from more settings>about mediabox),i think i have update for you.
              Did you have checked working temperature?
              Check sat part if you can,cccamd lines.
              Do you have your actual firmware files?
                Hi. Help me please find some apk remote program from smartphone.
                I think this need for Amlogic S905. Google TV not work
                UPD: found it - "Smart iRemote" in Google Play.
                  thinking on buying the k1 plus dvb t2 version . has anyone ordered that ?
                  digital tuner aspect is very appealing .
                  almost the perfect box only for the fact it doesn't support Bluetooth .
                  also if anyone is interested has the K1 plus (minus dvb) for 31 euro which is pretty impressive basically half price.
                    hello guys, i have a k1 plus with dvb-t2 everything works perfectly, but I have one problem the cccam well going smartadata work I am attaching two pictures for you to see what the problem is, if any of you the work if I can indicate how do, thanks
                      Thanks for the feeback, perfido. I was also looking into this tv box I saw on geekbuying. Is wifi fast enough to play 1080p videos on it?
                        OpenELEC for KI Plus soon.
                        Boot from SD
                        Thanks to @balbes150
                        Cheers
                          Boot from SD
                          Cheers
                            The manufacturer says that if you have asterisk is encrypted and does not work cccam. But if it works OpenELEC and neutrino cccam. It is a software problem. We must do force the manufacturer to give us support.
                              More options for Openelec KI Plus.
                              The author of the make :
                                The images are for model KI plus DVB-S2 / t2?
