Neomode Source Rom - Android 5.1.1 - MK902II and RKM V5
    Hello Community,
    Here i bring you my Android 5.1.1 Rom for the MK902II Device and other Compatible.
    This Rom is Build from Source, fresh and Clean in Version 1.0.
    #include <std/disclaimer.h> /*
    * I am not responsible for bricked devices, dead SD cards, thermonuclear
    * war, or the current economic crisis caused by you following these
    * directions. YOU are choosing to make these modifications, and
    * if you point your finger at me for messing up your device, I will
    * laugh at you. */
    I Tested the Rom and all Works Smooth and fine.
    Also, I Test Stream with Kodi and it Works Perfect.
    What Works?
    - Wifi
    - Bluetooth
    - Ethernet
    - Streaming in FullHD
    What must be Tested?
    Please Test the Camera and Report Back...
    How to Install?
    1.: Download from here ---> http://www.freak-tab.de/neomode/NSR_...0151108_V1.zip
    Reupload Done Parameter File in.
    2.: Flash it with Android Tool 2.xx
    After Flash the first Boot Take some Time, after Second Boot it is faster.
    Regards
    Neomode
    Awesome neomode I'll download and try out in few minutes.
      Hi Neomode no Peramiter file?
        Can use in Cloudnetgo CR12 2/8GB ?
        Can you enable HDMI-CEC in next verson ?
          Will test for mk903v 8gb ap6330.
          Should we use wasser kodi 15.1?
          Edit: No parameter file? Tried using a spare I had lying around and got nothing. Should I flash over stock?
          Currently Inactive on Freaktab.com
          I use: MK903V | MELE F10 Deluxe | Roku 3600R
          RIP: MK808b | MK809III | PIPO M9 Pro
            Sorry reupload running
              no root.
              how to do it.
                Can someone check 4K video playback, if it's working properly or in slow motion?
                  Will come in Next Version.
                  Can you tell me How the Rom is and Work?
                  Neomode
                    Tested Cameras, OMEGA universal web camera working , Microsoft LifeCam Studio 1080p HD working, bat not max rezolution
                      This is an excellent source rom - smooth, quick, bloat-free and with the core functionality to support further customization. I tested it on my RKM V5 after adding my own 4gb parameter file.
                      - Play Store fully operational after updating Google Play services
                      - YouTube smooth in 1080p
                      - Sleep mode seems to work! A light tap on the power button switches off the screen; a light cursor down switches it on. Wonderful, I don't know another V5 rom that does this (including those I've 'assembled' myself).
                      -Shutdown from the power menu doesn't turn the V5 off completely - the red light stays on.
                      - Kodi video is superb in most cases - stutter-free 1080p. The exception is the ITV Player addon, which is notorious for producing artefacts on every rom I've tested. It's an SD-only app and works best by turning off HW acceleration. BBC iPlayer runs beautifully.
                      - ethernet works well - I got 126mbps down on my 105mbps connection
                      - wifi, unfortunately seems to be only single-band (2.4ghz). I'm sure swapping another resource.img (from the Cloudnetgo rom perhaps) would open up 5ghz.
                      - not rooted but that's an easy fix after you flash TWRP.
                      Personally, I prefer the dpi you're using (160?) but some might prefer 240.
                      Antutu scores are not the highest (but what do those numbers really mean anyway?) - however, still very respectable. Like the RKM stock roms, this one seems to under-clock the CPU at 1.6 mhz max, with excellent thermal management as a result. Device runs cool.
                        After I flash TRRP and load to Recovery, I cannot us mouse and remote to click the button. How can you do it.
                          I have my usb remote/airmouse plugged in before I boot to recovery. It just works. Are you using TWRP 2.8.4?
                            Try using a wired mouse,I could not use my Air mouse in TWRP but a wireless mouse did work.
                            Neomode
                            Testing done on a RKM V5
                            Shows 4GB of app space (Nice size) Combined app & storage would be better if its possible
                            Logitech C270 Webcam works
                            Sixaxis App works fine using my PS3 controller :-)
                            Samsund M3 none powered HD works
                            Rooted using TWRP found here post 31 http://freaktab.com/forum/tv-player-...ber-2015/page3
                            Iroot,king root did not work
                            Would be nice to see the power button on the bottom status bar
                            I had to change to DPI to 240 as my old eyes aren't as good as they used to be
                            So far so good still testing More to come
                              Originally posted by neomode View Post
                              Hello Community,
                              Neomode
                              Hi Neomode.
                              Which verson Kodi you used ?
