Neomode Source Rom - Android 5.1.1 - MK902II and RKM V5
Originally posted by neomode View PostHello,
Yes, that can be, I have no 4K to Test.
This was the First Build I am sure it will be getting better in the Future.
Neomode
Second: Is it possible to mix your rom with wasser to get the 4K working ? in this case which part is responsible for resolution switching (Kernel / Resource)
So i can take only this part of wassers firmware as a temp solution until you fix it.
Anyone else having power issues? With MK903V, it does not shut off properly and since it does not, it also does not boot with CEC.
Also, the play services update, happens on the V5 stock rom, I just never tried updating it before. Reverted and it works fine, tried all sorts of playing with the date and time but nothing stopped it from crashing.Last edited by budgetgeek; 12 November 2015, 05:03.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
This Rom have the black level set to low which should be the correct setting but for some reason the low black level is incorrectly adjusted in all Rk3288 roms
And causes a black level banding in H265 videos , this problem can be solved only by setting the rom to Black level= High which is set correctly
In all Rk3288 roms and can get rid of the black level banding problem.
So does anyone know a way to change the black level in a rom from low to high ?
I have alot of problems with the rom.. (Iam using RKM 902II)
1. Sometimes it do not boot up so to disconnect the AC and connect it again.
2. When i load Kodi / SPMC and add my NFS / FTP OR samba network share it takes about 3-4 min to go into the folder first time(freezes with working icon). after it finish loading the folder it dont freeze anymore. If i exit kodi and go back in, the problem is back again.
3. Sound and video problems. the sound is behind the movie and sometimes the video flicks and pixels..
4. DTS, and HD audio Passthough do not work. Static sound...
Dont know if the kernel is bad?
4. DTS, and HD audio Passthough do not work. Static sound...Currently Inactive on Freaktab.com
Originally posted by neomode View PostOk, thanks for your Response. I am on the Update of my Rom.
Neomode
It is because some video cannot play with original KODI.
There are currently 3386 users online. 1 members and 3385 guests.
