M8s s812 ap6330 no Wifi, no Bluetooth !
Guest
Finally its working, and its working good, with latest kodi and addons , lot of goodies. This firmware is new build nr 2015 1110...and looks like with further updates as well...I am werry happy with it...Finally it s solved
Originally posted by dincis1 View PostWell my friend....,...................what can i say........just take your sd card and flash this thing........its f..king workingToday after work I flash this firmware , and see
I was slowly losing hope , I have probably 80 different firmware on the disk
I think I'll make a website with the base firmware`s
Guest
Originally posted by hipisxbit View PostThis is f..king good newsToday after work I flash this firmware , and see
Originally posted by dincis1 View PostOk....listen....everythyng is working just perfect excep one little thing.. After power off device, it stucks on boot...then i had to go with Twrp and clean dalvik cache, then it starts, the same on every boot....maby there is a workaround on that or just have to reflsh firmware
Maybe this is problem with TWRP ??? This is n200c firmware, TWRP version is for n200...?
And very important to me question, this rom have ROOT ?
Try cleaning applications Dalvik cache from google play , and write is problem solved https://play.google.com/store/search...ik-cache&hl=pl
Guest
Originally posted by hipisxbit View PostHeh , and already I thought it would be perfect , as you can see it is not. I did not turn off the tv box , it works all the time ... but tomorrow the makings of an update and check.
Guest
Hard brick, no signal , no revovery, not boot from autorom
Metod with shorten NAND pins not work....i think this is the endLast edited by hipisxbit; 22 November 2015, 12:22.
Guest
Yes its bit strange, when power off, and when power on its sometimes no signal at all, have to try again and its on....i think maybe the bootloader img is making troble i am not shore.....Do you know something about signing firmware zip files....? we could implement wifi and bluetooth folders to a diffrent firmware zip
Guest
Ithink this is not work, because i try replace this forder in root file manger - this is not work. I try signing too, but na sucess :/ I no idea it is work when I sucessed , because drivers is i system core...if system core dont use it, no effect..
Guest
I am still on this firmware, working good...only have to sort out wipe dalvik on every reboot...so another link , check this out..http://chinagadgetsreviews.blogspot....42_23.html?m=1
Guest
There is another trick for bricked boxes....put two files on sd card - uboot.bin and recovery.img, this will get you in recovery menu , can use nand pin connect as well
There are currently 1931 users online. 2 members and 1929 guests.
