Do you have any more this firmware? On Google drive it anymore ((( Can you throw me an email [email protected]
M8s s812 ap6330 no Wifi, no Bluetooth !
Originally posted by dincis1 View PostWell my friend....,...................what can i say........just take your sd card and flash this thing........its f..king working
Put Megatron mod v.3 - lan runs off and that pleases.
Guest
Originally posted by Morikone View Post
You left this firmware? You can throw it to me. I, too, such a PCB KCA-003 does not work WIFI and Bluetooth (((
Guest
Originally posted by dincis1 View PostHere is the link with fw files http://pan.baidu.com/wap/share/home?...404270&third=0 look for m8s nopmu wificompactbility, good look there is also bunch of different fw files you can check.
Last edited by Guest; 05 January 2016, 22:48. Reason: You can try this one as well, it will be a fresh install
If someone needs this firmware, I downloaded from baidu. Here on the forum my article with a link to the file sharing http://4pda.ru/forum/index.php?showt...#entry45955912
LINKS:
KOT49H.20151110 test-keys
1. http://4pda.ru/forum/index.php?showt...#entry45955912
2. https://yadi.sk/d/_r5daYAAmiCG4
3. https://cloud.mail.ru/public/MqKp/63RYkq9bj
4. https://drive.google.com/file/d/0B24...NUb3VtTWc/view
5. http://www.ex.ua/97322250?r=97322212
TWRP 2.8.7.0 M8N.img
TWRP 2.8.7.0 M8N.zip
Guest
Originally posted by Morikone View PostIf someone needs this firmware, I downloaded from baidu. Here on the forum my article with a link to the file sharing http://4pda.ru/forum/index.php?showt...#entry45955912
Good ....i had abig headdache with this box earlier on...firrmware works great. There are lot of firmwares on baidu, if you go from my profile you can get a lot off them
Guest
Originally posted by Morikone View PostI noticed a bug. This firmware (KOT49H.20151110 test-keys) does not allow recording with sd card (((How to heal - I Do not Know. Editing platform.xml solves nothing
Guest
Originally posted by Morikone View PostNo, it does not help. Where is the problem of the firmware ((Root Explorer can write to the memory card only if you mount a partition in the record. Other programs can not.
These problems not only for me alone. The forum 4pda we discussed this disease firmware.
I wasn't able to get any of the firmware posted in this thread to work but for anyone with the kca-003 board who has no WiFi or Bluetooth, after much searching and experimentation I found a burning tool image that actually works and I couldn't not share it.
https://drive.google.com/file/d/0B26...ew?usp=sharing
For some reason it didn't boot without using a u-boot.bin on the SD card that I know works but I worked out how to just flash the u-boot and all is fine. You may find that yours boots without the extra step. Good luck!
If anyone wants to try this for a kca-003 board with original
Build Number :
M8S build KOT49H.20150623 test-keys
Kernel Version :
3.10.33
foxluo@skykirin-Server #5
Wed Jun 17 09:02:15 CST 2015
Dpwnload usb card maker from here
https://mega.nz/#!bsUHyARa!N-ehx3OTqTR7PTojhfKOVFH1Vm48419UfMyiJmAkldI
and create a blank, at least 2gb in size, sd card with included u-boot.bin file.
Download the twrp bundle from here
https://mega.nz/#!D4FzSYwR!cMtDlQ_Zy...0z8OExJoHQ4cio
It contains twrp with two fresh install backups of the Mat (legacy) rom which is the one we want (but has a boot loop problem) and a rom which loads ok but has a few problems called stane.
Copy the twrp folder (inside the zip) and recovery.img file to the root of the sd card you just created.
Put the sd card into your android box and boot to twrp via the tooth pick method.
(with the power connector out, push a tooth pick into the 1/8" audio jack until you feel a click. Keep the tooth pick there and plug in the power. Keep the tooth pick in until the teamwin logo appears then you can let go)
I've found twrp to be a lot easier to use with an external mouse / keyboard either wireless or wired plugged into a usb port.
Restore the stane backup and reboot the box. (click restore. change the storage location to external sd card if need be and then select all partitions if they are not selected already)
Hopefully the stane rom will boot and when it gets to the welcome screen unplug the power to the box.
Reboot to twrp via the toothpick method again.
This time restore the legacy rom
When finished and still within twrp, wipe the cache and dalvik cache.
Reboot the box and hopefully the legacy rom will boot. Be patient as the legacy boot screen stays on for a while.
Check you havn't got the boot problem by unplugging the power and re-booting. if the legacy rom boots without sticking on the logo screen then you are good to go.
If you get the legacy boot screen freezing try restoring the stane rom again, then the legacy rom, then still within twrp, clear the cache and dalvik before you re-boot.
Hopefully that makes sense.
Let me know if anyone has sucess.
There are currently 4266 users online. 1 members and 4265 guests.
