Even though I have a wirless keyboard and mouse this could be the showstopper as my kids use the remote when they want to watch anything. Hats of to Wasser though!
CSA90 16 GIG Custom formwares
Having flashed the usual way both wassers i68 and r68 firmwares everything up to now is working peachy including gig Ethernet and dual wifi. I'm still testing various kodis as all seem to have the global stutter. The one thing that does work which I knew wouldn't is the IR remote. I took a backup from my CSA90 before flashing wassers and I was just wondering if there is anything I could load from my old rom to get my IR support back.
Even though I have a wirless keyboard and mouse this could be the showstopper as my kids use the remote when they want to watch anything. Hats of to Wasser though!Tags: None
You need to unpack Wasser's firmware and to take from there the parameter file.
Then you need to unpack CSA firmware and to take from there a kernel.img.
Using AndroidTool, flash a kernel to the section address according to the parameter.
P.S. AndroidTool can unpack firmwares, flash one-file firmware or separate images.Last edited by Diman3452; 22 November 2015, 20:01.
Originally posted by Diman3452 View PostYou need to unpack Wasser's firmware and to take from there the parameter file.
http://freaktab.com/filedata/fetch?id=523592
Laters and thanks for your help so far.
Heres the parameter file from the CSA which had a file ext of txt
FIRMWARE_VER: 5.1.0
MACHINE_MODEL:CSA9016G
MACHINE_ID: 007
MANUFACTURER: RK3368
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 3368
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
#KERNEL_IMG: 0x00280000
#FDT_NAME: rk-kernel.dtb
#RECOVER_KEY: 1,1,0,20,0
#in section; per section 512(0x200) bytes
CMDLINE: console=ttyS2 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0 x00002000@0x00004000(trust),0x00002000@0x00006000( misc),0x00008000@0x00008000(resource),0x00008000@0 x00010000(kernel),0x00010000@0x00018000(boot),0x00 010000@0x00028000(recovery),0x00038000@0x00038000( backup),0x00040000@0x00070000(cache),0x00002000@0x 000B0000(kpanic),0x00300000@0x000B2000(system),0x0 0008000@0x003B2000(metadata),0x00002000@0x003BA000 (baseparamer),0x00400000@0x003BC000(userdata),0x00 020000@0x007BC000(radical_update),-@0x007DC000(user)
And here's what I got from wassers which didn't have a file extn
FIRMWARE_VER: 5.1.1
MACHINE_MODEL: RK3368
MACHINE_ID: 007
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 3368
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
CMDLINE: console=ttyS2 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0 x00002000@0x00004000(trust),0x00002000@0x00006000( misc),0x00008000@0x00008000(resource),0x00008000@0 x00010000(kernel),0x00010000@0x00018000(boot),0x00 010000@0x00028000(recovery),0x00038000@0x00038000( backup),0x00040000@0x00070000(cache),0x00002000@0x 000B0000(kpanic),0x00200000@0x000B2000(system),0x0 0008000@0x002B2000(metadata),0x00002000@0x002BA000 (baseparamer),0x00020000@0x002BC000(radical_update ),-@0x002DC000(userdata)
Originally posted by Diman3452 View PostFind and open AndroidTool program on the first tab. In line a parameter specify a way to the parameter file from wasser's firmware.
Remove marks from all check boxes, leave only on a kernel. Specify a way to a kernel from CSA firmware. Run
On the attached I keep everything in csa90 and the parameter file is the one from the wasser i68 and the kernel from csa90 but I reckon on wasser build theres too much difference in csa90 stock.Last edited by homeruk187; 22 November 2015, 21:17.
There are currently 6380 users online. 1 members and 6379 guests.
