M8S - USB Burning Tool failing at 2%
I have the same problem
[22:03:48 031][HUB5-3][Inf]--Device is connected
[22:03:48 031][HUB5-3][Inf]--Close device handle 0x00000250
[22:03:48 093][HUB5-3][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&21af9bf0&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000250
[22:03:53 156][HUB5-3][Inf]--0-7-0-16
[22:03:53 156][HUB5-3][Inf]--CheckFileRunState succeed
[22:03:53 156][HUB5-3][Inf]-- low_power
[22:03:53 156][HUB5-3][Inf]--Send command success
[22:03:53 156][HUB5-3][Inf]--Read command status success
[22:03:53 156][HUB5-3][Inf]-------------ERASE FLASH-----------
[22:03:53 156][HUB5-3][Inf]--disk_initial 2
[22:03:53 250][HUB5-3][Err]--failed:[22:03:53 250][HUB5-3][Err]--Check command return failed
[22:03:53 265][HUB5-3][Err]--[0x30201004]UBOOT/Disk initialize/Send command/Error result
[22:03:53 281][HUB5-3][Inf]--Close device handle 0x00000250
Any sugestions ?? Help ?
try later version usb burntool and grab bew img file both file can be found here http://freaktab.com/forum/tv-player-...ial#post553667
Bugs are Sons of Glitches!
JustMe
Originally posted by leafs87 View PostBlue light isn't coming on and the box doesn't want to power up. It connects to USB Burning Tool however fails at 2% with the following...any ideas?What is the world if you don't explore?
There are currently 2823 users online. 0 members and 2823 guests.
