Vensmile MXV S805 latest ROM
ok, this is the only problem that I face with the firmware that I am usingalways I need to press power button on top to turn the device on.. hope it'll be fixed shortly.. I think they need to fix something in bootloader for this to work.
Also I was not able to type using the remote keys (toggle button never worked for me) - is it working in this rom ? Though I dont use the factory remote but still it'll be quite good if it works in this rom.
Originally posted by mystguy View Postok, this is the only problem that I face with the firmware that I am usingalways I need to press power button on top to turn the device on.. hope it'll be fixed shortly.. I think they need to fix something in bootloader for this to work.
Originally posted by matrixebiz View PostDo you have an MXV with this Firmware on it? i don't want to update it if I can't use the remote to turn it on.
http://freaktab.com/forum/tv-player-...m-for-mxv-s805
and yes, I am not able to power on the device using remote when its fully shutdown (red led on). I can turn it on when its in hibernating mode though.
Just curious to know - are you able to turn on your device using the remote? If yes then it'll be good to get the rom that your device is having,
Ok, that is a different firmware so i'll try this one tonight and let you know. If the button on the top of the box is pressed to turn it off then you have to push the button again to turn it on but if you use the top button to turn it on then use the Remote to turn it off then I can continue to use the remote to turn it On/Off and not worry about the box button.
ok, so its actually the same for all the roms I believe.. when you power on the device (connect to power) - then by default its in off state (red led on) - in this case we need to press power button on top to turn it on - remote control doesnt work here. Once device is on then you can use remote control to turn it off/on. But again - if you long press the remote power button then it'll prompt you to shut the device down - if you does so then again you need to press power button on the device to turn it back on - remote wont work here again - atleast this is how the rom that I posted works.,
There are currently 3189 users online. 1 members and 3188 guests.
