Official Specs as Posted By MINIX John @ http://www.minixforum.com/threads/ou...cription.9393/
SPECS:
- Quad Cortex A53 CPU (next generation 64-bit architecture)
- Penta Core Mali-450 GPU
- Supports up to 10-bit – Not found on previous MINIX models, or even RockChip’s latest generation chipsets – RK3368.
- Supports ‘True’ 4K @ 60Hz – NEO X8-H Plus only supports 4K @ 30Hz – another big strength of NEO U1.
- HDMI 2.0, HDCP 2.2 – NEO U1 has Miracast support for all smartphone brands.
- 2GB RAM
- 16GB eMMC 5.0 (MLC)
- Gigabit Ethernet
- Dual-Band 2 x 2 MIMO ac Wi-Fi – Inclusion of an internal antenna in addition to the external antenna, offering incredible connectivity and Wi-Fi performance – superior to all previous MINIX models.
- Bluetooth 4.1 – Instead of Bluetooth 4.0 found on previous MINIX models.
- Android Lollipop 5.1 – We have kept the MINIX Launcher but the overall user interface has now improved – the settings menu etc. look similar to Android TV. Much easier to navigate, improved functionality and appearance.
- Same form factor as NEO X8-H Plus but ports have been repositioned (all 3 USB ports on the right-side).
- NEO U1 can be powered on/off using the included IR-Remote, no need to use the physical power button on the side of the main unit like previous models.
- Built-in F.O.T.A (Firmware-Over-The-Air) Update System – so there should never be any need to manually update/install the firmware.
- Supports the following:
7.1 and 5.1 surround sound pass through over HDMI
DD+/DTS (pass-through)
Dolby TrueHD (pass-through)
