Im surprised theyve still kept the same design all of these years. I mean there have been a few changes to it such as external antenna and rubberized feet on the bottom and what not but as a whole it looks nearly identical from year to year. Would def be nice if the flagship could get an aluminum case and with an internal fan / vents. or something. I guess its really not just MINIX though cooling always seems to be the last thing on android tv boxes manufacturers mind yet no one ever does anything really stop it from gen to gen.
MINIX NEO U1 - Amlogic S905 / Android 5.1
Yep this is annoying!
>3. Volume bar bug - appears randomly on the screen without any remote control interaction.
FYI, the MX S905 box has even a worse issue with this! Like every few seconds!
___________
I have not seen this happen to me but it's probably how the box is detecting HDMI connection.
>6. Reverts to 720p. Upon reboot (not sure if it happens every time, but it happened at least twice so far), the screen resolution reverts to 720p (from 1080p) even when the "return to default resolution" is set to "off".
_______________________
As of now while trying to root this box, I bricked it. Waiting for Ken from Minix to give me a full ROM package.
I screwed up a Selinux permission and cannot fix it via update.zip anymore.
Rooting Lillipop is a bitch let me tell you!
Can produce some of the same issues mentioned on the S95 Telos.
Pop up Volume I find only appears on monitors as in computer more than TV's only every now and again.
Tested same files as mulderfox mentioned, the .TS Demo sounded fine through Sony amp.
Movie mentioned has the Clipping or clicks every 10 ~ 20 seconds.
Used HDMI pass through Kodi, to Sony amp to Sony 40in 1080 TV.
Tested a 27 GB True HD movie, all played fine no clipping noticed local via USB 3 stick and ethernet
Hard Disk Size thing is there also, using Paragon NTFS plugin and Total Commander is a solution if you need to browse for files. (you know that)
Cheers
Yes I have noticed this!
You can recreate it.... Go to Google Play and click the search.
Try to type in a name with a space e.g. "adb wifi".
When you hit the space after typing adb it gives you a back mouse click and exits google play
Bad bug!
I will fix it in a custom ROM
Bad bug!
Yep it made me update em before installing other apps so everything is up to date. Ive done some pretty good comparisons too between the U1 the s95 and the K1 and I will just say it now, the performance difference between the boxes certainly does not account for the premium MINIX is charging here in terms of pricing. Will post pictures, and video reviews in the next day or two for all to see first hand.
Originally posted by alwaysbless View PostYep it made me update em before installing other apps so everything is up to date. Ive done some pretty good comparisons too between the U1 the s95 and the K1 and I will just say it now, the performance difference between the boxes certainly does not account for the premium MINIX is charging here in terms of pricing. Will post pictures, and video reviews in the next day or two for all to see first hand.
Well I tried to add pictures, appears forum is having issues with uploading and arraingement of images so everything I uploaded was in a 50x50 resolution. Sorry guys but here is a link to the pictures on imgurs site if you wanna check it out there (sadly embeding isnt working either). http://imgur.com/a/eAM9v/all
I will wait for the S912...
It´s funny, I think... --> Zoomtak T8 plus Quad Core Android Smart TV Box Dual Wifi Kodi 15.2 Amlogic S912 TV Box
will released at the CEC2016 and there is already a clone model in pipeline, Source: http://www.alibaba.com/product-detail/Zoomtak-T8-plus-Quad-Core-Android_60369864249.html
There are currently 1393 users online. 0 members and 1393 guests.
