MK808 RK3066 any "t" gotchas?
Got suckered and bought a rk3188 stick that was really a 3188t, which I could have lived with, but they also used the cheapest garbage nand on earth that guaranteed system corruption at some point. Any similar issues with MK808 RK3066 sticks to look out for??Tags: None
You'll find that the RK3066 is not as fast as the RK3188T, and then some have been limited to 1.0 mhz. Aside from that, buying an MK808 is almost a crapshoot as to what you may eventually get. They have been made with different wifi/bluetooth modules (RK901, RK903, AP6210, RTL8723, MT5931, MT6622, etc...), different processors, (Rockchip, AMLogic, Allwinner). The most recent and most modern model has the AMLogic S805 processor and should work pretty well, and you got a good deal on it if you paid $15.00. Good luck!Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
These are the "claimed" specs. which if true seem decent, I just want a mini-box to run linux on, the current one I have would be fine but even running from the sd card with the craptactular nand a week is about as long as an image has lasted, and it even manged to corrupt a samsung 32gb card to the point it would not format..
CPU:RK3066 Dual Core 1.6Ghz (Cortex-A9)
RAM:1GB DDR3
ROM:8GB NAND FLASH
EXPAND MICRO SD:T-Flash(Maximum support 32GB)
Video Format:WMV/ASF/MP4/3GP/3G2M4V/AVI/MJPEG/RV10/Divx/VC-1/MPEG-2/MPEG-4/H.263/H.264/1280*720 HD 30fps,1080/720*480 D1 30fps.
Audio Format support:MP3/WMA/APE/FLAC/AAC/OGG/AC3/WAV
Picture Format support: Max.8000x8000 JPEG BMP GIF PNG
Wifi:Support 802.11 b/g/n
Bluetooth:Support bLUETOOTH v4.0
Output MINI HDMI Port
OS Google Android 4.1(flash 11.x,HTML5)
Ports:
1* Mini USB,Support OTG/HOST(USB Port RJ45)
1* Standard USB
1* Mini USB For charging
1* TF card slot
1* Blue LED (When connect to power)
1* Physical botton(for upgrading software)
Dimension:88mm*31.5mm*15.8mm
Color:Black
http://www.amazon.com/gp/product/B00DYPZ0YY?psc=1&redirect=true&ref_=oh_aui_detailp age_o00_s00
There are currently 2522 users online. 1 members and 2521 guests.
