HPH NT-V8 ROM V1.1 by mo123
    - Universal storage(around 12.5GB)
    - 1080p/1440p Youtube, should work better now
    - Google Movie support
    - MXPlayer with DTS/AC3 Codec
    - Streaming addons in Kodi should work better
    - 4:3 Aspect ratio videos can now stretch fullscreen non-linear
    - Pulsar and other torrent addons working in Kodi
    - Audio sync improved
    - to root - Go to Accessibility options
    Download Link:
    Here Click image for larger version
Name:	HPH NT-V8.JPG
    Launcher Menu
    Easy Root/Unroot Option
    LeHome Assistant Remote Control App for Smartphones to control HPH NT-V8 TV Box(app not working on other boxes)
    Instructions:
    Before Installation
    - Make sure USB Power saving mode is disabled for the USB Port you use to flash the device
    - Use a PC Back USB Port and not ones from the front or a laptop
    - Pause Antivirus software for 10 minutes to not interfere with the flashing or cause high disk usage.
    - Make sure device was connected to PC before in flash mode and drivers were installed
    To Install the drivers
    1. If flashing for the first time, you need to install the drivers with DriverInstall.exe
    2. If you recently upgraded your operating system to Windows 8.1 or higher, it's also a good idea to install the latest drivers.
    3. Let your PC recognize the device and automatically install the drivers
    - Connect device with OTG Port and cable to PC
    - Now connect the power adapter
    - Before plugging the power adapter into the device, hold a paperclip into the reset hole of the device, keep holding it while connecting the power
    You will hear a 'click sound' that Windows has now recognized the USB device.
    - It will ask to install the drivers or install it automatically.
    Flashing the ROM
    1. Select 'Upgrade Firmware' in AndroidTool v2.35(Second tab)
    2. Click on the 'Firmware' button to load the firmware(update.img that you extracted from the 7zip compressed file)
    3. Click 'EraseFlash' to wipe your device, wait for it to finish.
    4. Click 'Upgrade' to flash the new firmware.
    5. Wait about 2 minutes after flashing and before unplugging device for firmware to settle.
    6. Disconnect from PC and connect to TV.
    Enjoy
    HD Audio
    Kodi
    You need to turn off the following settings in Kodi
    (But they should be disabled by default)
    - Keep audio device alive -- Off
    - Play GUI sounds -- Never
    HDMI Bitstream
    Android
    - Choose HDMI Bitstream in Android Sound Settings
    SPDIF Passthrough
    Android
    - Choose SPDIF Passthrough in Android Sound Settings
    If you get black screen stutters
    -system,settings, audio output, output config= fixed
    -system, video, playback, adjust display refresh rate= off
    Can always try nightly Kodi
    http://mirrors.kodi.tv/nightlies/and...rmeabi-v7a.apk
    Originally posted by mulderfox
    thanks!
    Please give feedback.
    I see you wanted to get a rooted ROM, this should work.
    The ROM will also work on other devices just like the UGOOS ROM.
      zidoo x6 is included to other devices?
        Yes.
        It should work on Zidoo devices.
        Only thing not working might be different IR Remote, but use an airmouse. Airmouses can work on any device and makes it much easier to navigate.
        Power Off button might not shut off device. For this you can flash Zidoo resource.img seperately afterwards if needed.
          Thanks a lot. I am downloading the rom now.I 'll post my feedback after testing.
            hi mo123,
            your rom looks nice, can you do a version with this kernel.img and resource.img for tronsmart r68 gigabit?
              Installed the rom. Is it possible to get the kodi from the rom as apk. I updated to Kodi Jarvis not happy with that​
                It is in the /system/preinstall folder.
                  i have problems with kodi . the movie from my nas is glitching before i had m8s with no problems with this setup. my box is hand hot is that normal
                    Wait for my new ROM.
                    The chipset can get very hot, it's normal.
                      thanks for the reply.
                      waiting for your next rom,
                        thanks mo123 for your rom and backup tool. the rom works great on my zidoo x6. however ethernet and remote don't work.
                        but I use wifi and usb wireless keyboard/mouse so it's all good.
                        is there a way you can add support for x6 remote in your next version?
                        thanks again
                          Any small fixes/updates that are easy to do to include in next ROM?
                          I will upload new ROM later today if everything goes smooth.
                          It will also have RK Kodi 16 final and work well, I tested several videos and settings.
                          Also have 4K Kodi, correct temperature display in Kodi, auto frame-rate switching, 3D etc.
                          Will also be dual-boot.
                          There are just some small fixes for RK3368 still to be done by Rockchip and then RK3368 platform will be very stable.
                            top dog
                              Hello mo123, please, work this ROM also on Nexbox Z68 ? Thanks.
