TWRP 2.8.6 for Cube T9
    - more partitions backup/restore
    - can mount sd card and internal sd card
    - inbuilt ability to root T9 (no need any zip file)
    - new su-binary and supersu to the version (chainfire supersu v2.61)
    How to Install
    method 1 (install zip via TWRP)
    - download " T9_TWRP286_su261.zip ", do not extract and place file to external SD card
    - Boot your device to TWRP
    - press install then select " T9_TWRP286_su261.zip ", then swipe to install
    method 2 ( flash via sp-flash tool )
    - download " T9_TWRP286_su261.zip " ,etract recovery image (T9_Twrp286_su261.img )
    - flash via sp-flash tool
    Download link below
    Nice. Now we just need a lollipop rom.
      Where do i find the options about to root the T9?
        ###.. 3-Step to get Root Without PC.. ###
        All thing your need are here.
        1 Download and install this 3 app to your device,
        - 1,1 KingRoot.apk
        - 1.2 flashify.apk
        - 1.3 Qboot.apk
        2. Download TWRP image and all this zip file and place to internal sdcard,
        - 2.1 twrp286su249.img
        - 2.2 T9_v107.zip (this file is a stock rom V1.07, flashable-zip)
        - 2.3 T9_v108.zip (this file is a stock rom V1.08, flashable-zip)
        - 2.4 T9_del_Ch_app.zip (wait for upload)
        - 2.5 T9_mod_001.zip (this file is my custom rom, rooted ,base on v1.08,)
        - 2.6 107_stock_recovery.zip
        - 2.7 108_stock_recovery.zip
        # # list below please wait for prepair and upload
        - eng_language.zip
        - soft_button.zip
        - host_Ad_block.zip
        - pplatform_fix.zip
        - su249.zip
        - pada_launcher.zip
          This TWRP, have an inbuilt-ability-scrip to root the Cube T9 (kitkat only),
          After flashed this TWRP , boot your device to new twrp .
          When you reboot to system or recovery (exit TWRP),
          This TWRP will auto-detect files "su" and "SuperSU.apk" in system partition.
          if SuperSU and su is not installed
          TWRP will ask you for root ,
          then " press and swipe" on screen to confirm root.
          if you don't need to install root
          then press " Do not install "
            I mmrrdd, Can you please mad a clear tuto in order to ROOT T9 (1.07) thanks for newbees ;-)
              That's great mmrrdd.
              Will be frontpaged in next few days here if you don't mind http://freaktab.com/forum/mtk-based-...tools-mods-etc . I'm far away from my PC right now.
              Casaboy91 what you don't understand when you are looking at the post with pictures above yours?
              Flash this new TWRP through old one (if you have one already installed) or extract recovery.img file from archive and flash this file with SPFlash tool.
              Look here http://freaktab.com/forum/mtk-based-...tools-mods-etc on first 10 pages you'll find all information about SPFlash Tool.
              That's a two minutes job.
                Will be frontpaged in next few days here if you don't mind... .
                I don't mind and agree with that.
                  Thx mmrrdd I going to try it this week ;-) it will be my first root operation ;-( very new bees
                    Thanks!
                    Done
                      HI mmrrdd
                      How Boot to TWRP (non root Cube T9 V1.08).
                      Thx for your support.
                      Rgds.
                        I've put in SD card download T9_TWRP286_su261.zip without extract but I do not know how Boot to TWRP ? ;-(
                        Sorry I'm newbees and English not my natural language ;-)
                        Thx
                          This recovery (2.8.6.0) has a very serious problem.
                          In the backup menu, the partition \data is missing.
                          This is essential for the distribution of custom Rom XnetfoX.
                          Instead there are all the other partitions.
                          The lack of the given partition may be linked to the fact that my given partition is of 8Gb and not of 2 Gb as in stock?
                            HI mmrrdd
                            How Boot to TWRP (mine is non root Cube T9 V1.08).
                            when I press
                            press power button & VOL +I've many choice :
                            Reboot System Now
                            aplly update from ADB
                            aplly update from sdcard
                            aplly update from sdcard 2
                            aplly update from cache
                            wipe data/factory reset
                            backup user data
                            restore user data
                            root integrity check
                            thanks & kind rgds.
                              Originally posted by Casaboy91 View Post
                              HI mmrrdd
                              when I press
                              Reboot System Now
                              backup user data
                              restore user data
                              thanks & kind rgds.
                              You have stock recovery not twrp you must flash it with spflashtool
