TWRP 2.8.6 for Cube T9
    How to Dump Rom by TWRP Terminal Command
    1.Set TWPP screen-off 's timer
    2. Dumping Process
    (if you don't know ,how to mount system and sd card ,see here...
    http://freaktab.com/forum/mtk-based-...256#post547256 )
    3. Basic Linux Terminal Command
      Thx Hocuspocus, should I applied method 2 ? Someone can show me clearly how to do it ;-(
        when I try to load Scater from T9_Twrp286_su261, I've an error 8417 (the load scatter file is invalid !)
          It's my first time ;-) sorry
            Originally posted by mmrrdd View Post
            Thank to devilz-wolit for your comment,
            could your give me a link of XenetfoX ROM,
            I will rebuild user data in backup menu for you.
            Please wait for few day.
            I try to port all version of twrp to cube T9 ,and found some problem about data partition on /dev/block/mmcblk0p18 and
            /dev/block/mmcblk0p19 ,that the reason to hide this partition from backup menu.
            http://freaktab.com/forum/mtk-based-...873#post500873
            or
            http://www.androidiani.com/forum/mod...ml#post6709867
            I also suggest to replace SuperSU 2.61 with SuperSU 2.60 or with new 2.62
            Version 2.61 gives problems with repeated requests to update the binary files
              HI team, Sorry to spam you but please help how can you root T9 V1.08
                Here http://freaktab.com/forum/mtk-based-...-etc#post23135 you can find instruction to spflah twrp and then to root via twrp method i preferito or root directly via kingroot...
                  THX hocuspocus69, how can I backup my T9, then how can I flash it wich file needed ;-)
                  many thanks for your support
                    what is difference between flash and root
                      I read firstly a should root (how plz), then Imust save NVRAM IMEI, adresses MAC & wifi etc before instal custom rom
                      It's right ?
                        It's right ?
                        This is detailed ...but: in Italian
                          Thx devilz-wolit, But First root or Flash ???
                            If you want to run the root of T9 with TWRP metod, you have to flash the recovery TWRP.
                            If you then want to install my custom Rom uses version 2.8.4.0 of TWRP and not 2.8.6.0
                            Follow exactly the steps of Androidiani (you can also find links to everything you need).
                            ...In any case we are not talking about how to make the root. For this there is a specific thread
                              sorry devilz-wolit, thx to waste your time with me ;-)
                                devilz-wolit, FYI I've request registration to http://www.androidiani.com But not yet approved ;-( since this morning
