New ROM
Originally posted by neomode View PostCan you open your Device and make Photo´s of it.
We must know which Wifi you got to help you.
Neomode
From I can see it's a AP6210, but in any case you have both sides of it here:
and
Best regards
Thank you!!
Eduardo
Originally posted by bigall123 View Posthi guys. on the mk802iv eny new rom needs to have a look at the B/T problem it shocking on Xbmc play back. i have all the settings right it shuders alot. i also have the mk808b & it works fine with the finles bob custum rom installed. Thanks.
@jedu
I have buy From lightake.com the same mini pc as ugoo802 without heatshink.
The correct name of stick is Netxeon_MK906_V2.0. This stick have PMIC the act8846 like the T428 and many others but the WIFI+BT chip is the AP6210 like MK908.
I have the same problem with you because my stick is not working from beginning I take the dmesg from serial console the problem in my case is the corrupted firmware I send the file to lightake.com and I asked the firmware and this is the answer:
Hi friend,
Thanks for your waiting.
But after confirmed with our supplier, there was no any firmware file with this item, and we checked every paroduct careful before shippment. Whether it can't work at all or it can't work on after download some softwares?
Could you pls kindly confirm that again?
So I use my stick with MK802 rom and external 8188EU usb wifi
I have try and others but the mk908 with AP6210 is not working for me.
If any one can make rom dump from lightake.com stick (I think all is same) can help many people I think.
And stay away from lightake.com
Just to finish the thread...
The device seems to be internally a Tronsmart 908. I downloaded as sugested by vmkogeretla a collection of ROMs at http://yadi.sk/d/T9LLU1wH5tZRa
Although I was recommended to use 4.1_mk809III_Finless1.4, it didn't work for me but finless 1.5 ROM for tronsmart 908 did the the trick.
I still don't know why other firmwares for Tronsmart 908 didn't work before. Perhaps I didn't use Restore instead of Upgrade.
A great thank you to everybody that has helped me.
Eduardo
There are currently 2476 users online. 2 members and 2474 guests.
