Jesurun NX003II Quad-Core
GuestTags: None
Get this sample some days ago, and tested, the system is bad, always crash, i am not sure if they have fixed the problem, i will try to get the sample tomorrow,and test for you guys.
Geekbuying will have those rk3188 device which has internal camera. seems this function is also useful for some of customersLooking for developers
Guest
I would not advice anyone to buy a jesurun product since there isnt any support from them. Sent them a e-mail 2 months ago about my jesurum mp019 android box and no answer, cant find any official patches or anything online.
Before buying anything from china be sure that you can get patches, new roms, unbrick guides and such.Tablets: Asus Transformer pad tf300t | pipo smart s1
Phones: Samsung Galaxy S2
Guest
Originally posted by geekbuying View PostGet this sample some days ago, and tested, the system is bad, always crash, i am not sure if they have fixed the problem, i will try to get the sample tomorrow,and test for you guys.
Guest
OK I got this Model and had had some Problems with it. Turn it off but it want not turn on again.
So I press reset Wipe Dalvik Cache and then all o.k.
Right now i Test it:
The Cam is a 2 M Cam. Not so good but sometimes for Skype ok.
The Internal Wifi Antenna is OK but you can connect a Wifi Antenna from the outside, these were also in the Packet.
Antutu Reportet 13973
Android is 4.1.1 but with a 3.0.36+ Kernel
The Kernel is a full HD Kernel !
Ram 2 GB
ROM 8 GB
SD-Card Slot up to 32GB
1x Micro USB, 1x Full Size USB Port
So far so good. It is not a bad Device.
Neomode
Originally posted by neomode View PostI have the same Device I will Test which ROM, can installed.
Neomode
I'm having problems installing the drivers on my windows 8 machine. Can someone here point me in the right direction?
Originally posted by neomode View PostRight now I don't know witch WiFi Chip is inside.
I will make a Custom ROM for it, but Bob and I have a lot of ROMs to make.
Please wait a little bit.
If there is anything I can do on my side to help let me know. Wouldn't mind learning a bit about these new devices
There are currently 2677 users online. 1 members and 2676 guests.
