Well guys here is a rom for this very nice box!
Changelog:
V1.3C:
- Fixed USB HDD's/USB Stick's mounting points (you can use the MK68_Boot_Patch.zip to flash by TWRP(recovery) if you don't want to flash the whole rom!)
V1.3B:
- Updated Kodi to 16.0 Final with zidoo custom patches + mpeg1/2 fix + some from SPMC patches (4k GUI support etc...)!
- Updated the media libs to the latest ones.
V1.3
- Updated Kodi to Rk Kodi 16 RC4!
- Updated media library's ( some Tv provider apps work good now, youtube work better now but still not 100% )
- Updated gapps
- Updated kernel
- Some fixes(from RK) to the sdk for the audio(not tested i dont have a 5.1 or 7.1 sound system)
- To update the root(su) from 2.46 to 2.67 use the zip that i supply and apply by recovery(OPTIONAL)! Don't try to update by playstore it will fail..
- Other small fixes nothing special!
V1.2
- Fixed Unified Storage.
V1.1
- Fixed external sdcard not working.
- "Fixed"? Passthrough AC3/DTS in Kodi (i don't have a way to test it.. and don't forget to enable 1º in android sound settings the Spdif Passthrough)
V1
- Built from updated sdk.
- Unified Storage
- TWRP 2.8.7.0, it will be installed after first boot ( thks abdul_pt )
- ADB shell as root
- Rooted with SuperSU
- init.d support.
- Xbox360 support, wireless and cable (original or clone wifi dongle)
- Some apps installed, including my custom rockchip kodi 15.2 updated librtmp and cpu temp working.
- Added setup wizard.
- Simple launcher so use your favorite launcher....
- Updated kernel.
I also cleaned,updated and fix some things!
Want to buy me a beer?
How to install:
- Power off your MK68
- Grab a paper clip insert in the reset hole in under the box. Press and hold the reset button now and insert the usb-a cable to the otg port(no need to use the power supply) . Your MK68 should appear as loader device.
- Choose your image(s), press restore.
- wait around 5/6 minutes the 1º boot (SO DON'T DESPAIR...)
DOWNLOAD V1.3C FULL ROM:
- http://freak-tab.de/luis/MK68/RKM_MK68_SCv1.3C.img.7z
- md5 Checksum - F3A9604F516BEDCD1C95F7E532A836D5
DOWNLOAD UPDATE ROOT:
- http://freak-tab.de/luis/MK68/SuperS...0121175247.zip
- MD5 Checksum - 4A620AC84476E8FFE9762ECB18C4E2D5
DOWNLOAD PATCH v1.3B to v1.3C:
- http://freak-tab.de/luis/MK68/MK68_Boot_Patch.zip
- md5 Checksum - AE666A26925B46116B5685EB8D0CDF32
USE AT YOU OWN RISK
