[ROM] SC_V1.3C Custom Rom RKM MK68
Originally posted by 251643711 View PostNo transplant that would be no way to perfect the use of Kodi, I can only use half a transplant zidoo go!!!!!!! I am a Chinese player, English is not good, I am sorry!!!!!!
dear SuperCeleron
i have generic tv box (t052) with same as mk68 pcb... but this one have led clock display...
i love this custom rom. but the display not working with this rom.
is there a way to make the led clock working again?
thanksYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
thanks
Maybe, if you have a link to the original rom!
But i got firmware for T051 which have same display clock.
That the link if you mind to check.
T051 and t052 have same rk3368 and 5.1 android...
Hope there is a chance it may help you find the solution...
I looking everywhere... I cant find the stock firmware and i already flash to your SC 1.3b rom without backing up old rom.
LED light might just be dts file or maybe driver in kernel(then you have no hope).
Your firmware also has different wifi so it won't work but ethernet might.
Honestly im not understand with building rom...
If the stock rom are realy important, then i will try to search again tomorrow morning...
Thanks superceleron n mo123
1.35am my time now.. Lol
Originally posted by superceleron View PostSame cpu and android but different wifi chip! for what i see the t052 have the same chip as mk68 but t051 have another wifi chip and only 8gb!
I really need the one for that device! or else you have to live without the clock
Dear SuperC...
i found out that RKM mk68 stock rom are compatible with the led display....
look at the pic.. its working...displaying clock bluetooth hdmi wifi lan av and spdif
https://copy.com/ZQGyLfWAMUHeb7TQ
thats the official link from rikomagic.com...
is this rom can help?
thanks again^^You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by superceleron View Posthooooo damm, sorry cant help since i use another sdk
It need big changes to the sdk for that to work... but im going to build a test version, if it works all fine if it don't sorry :/
Its ok^^
I will wait...
I still using your rom because it very stable...
That display just a clock anyway...
Hi I just install your rom 1.3B version, and I have next problem with USB ports;
I have an ext sdcard and two external hard drives (Toshiba & WD) and your rom detects only one of them and it always mark as USB_DISK0 into any USB port.
Kodi works perfectly and change automatically my TV to 24 Hz, thanks!
And I still have problems with cuts audio optical out with my Logitech Z5500, but that happened to me with the official rom.
Greetings.Last edited by MALOW; 25 February 2016, 05:11.
There are currently 2601 users online. 0 members and 2601 guests.
