28/12/2015 - [ROM] CX-919 CM12.1 (Lollipop 5.1.1)
    Android 5.1.1 for the CX-919 (CM12.1)
    This ROM needs first generation bootloader so follow instructions precisely.
    Bugs :- Bluetooth
    For smoother UI feeling you can lower or disable all animation scales in developer options (Tap 5 times on build number in the settings menu ´´about device´´ to enable developer settings in the main menu)
    Kernel features
    - HDMI Output with real REC.709 16-235 color support!
    - pureXbmc with dolby/dts passthrough
    - 720/1080 24P/25P support
    - HDMI-CEC support
    1920x1080 at 60, 50, 30, 25, 24 Hz
    1280x720 at 60, 50, 30, 25, 24 Hz
    720x576 at 50 Hz
    720x480 at 60 Hz
    640x480 at 60 Hz
    Kernel doubles the framerate at 24/25Hz if your Monitor supports.
    24/25 will be displayed at 48/50.
    Instructions (be aware: it is your own risk!) :
    HTML Code:
    Connect the usb port of your device to your PC via USB cable
    1) installation of the usb-driver (skip if you have the driver installed already)
    2) change the loader
    a) run RKDevelopTool.exe
    b) press button with the 3 points: load the loader (v1.24)
    c) press button Erase ID Block
    d) press button Erase All Blocks
    e) press button Download
    f) exit RKDevelopTool.exe
    3) flash the firmware
    a) run RKAndroidTool
    b) hold reset button on your device while plugging in power
    c) press button EraseIDB
    d) press button Run and wait for it to finish flashing your device
    c) the device will reboot in recovery, do factory reset, wipe cache, wipe dalvik cache
    d) reboot
    Enjoy!
    Changelog :
    V1 :
    - Initial Release
    26/12/2015 V1.1 :
    - Fixed screen orientation
    - Fixed Wifi
    - Added kernel modules for touch screens
    - Spoofed as Nexus 10 for play store compatibility
    28/12/2015 V1.2 :
    - More kernel modules for external devices
    - Fast usb ethernet adapter support
    - More supported codecs (3gp, avi, wmv, flv)
    - DPI change for better compatibility
    - Removed unnecessary apps
    - Used walter kernel as standard (For description go to http://freaktab.com/forum/tv-player-...now-for-cx-919)
    03/01/2016 V1.3 :
    - Clean Base
    - Fixed Storage
    LINK : https://mega.nz/#!xYJXxA6Y!tZvRzGrPD..._lLspWJHsKenho
    Credits :
    Oma7144 for the V88 Chuwi rom at CrewRKtablets. (RK3188 Development) - I used this as a base to create a compatible working rom on our CX-919.
    Walter77 for his awesome kernel.
    File uploaded! Feel free to create mirrors, i will add them to the OP.
      Awesome! Can't help myself with development but I'm very glad to see this device still getting some love
        UPDATED LINK V1,1.
        26/12/2015 V1.1 :
        - Fixed Wifi
        - Alot more more small fixes
          New update.
          28/12/2015 V1.2 :
            This works pretty good so far, fast and smooth. Thank you!
              Is there any Miracast support? (Ability to cast from a tablet to the CX-919, for example.)
                I heard that the cx919 and the mk908ii preT models are almost identical. will this work for the mk908ii?
                  I´m not sure about miracast support. If it´s included in either stock android or cyanogenmod it should be there and working
                  The mk908ii should work too regardless of a T model. I´m not sure if it has the same wifi chip as the CX-919.
                  Try it and report, flashing won´t do any harm to a RK3188(T) Device.
                    New update.
                    02/01/2016 V1.3 :
                    PULLED
                      Any kernel DEV who can help me out with Bluetooth and HW acceleration​ ?
                        Thanks, michie!
                          Wonder if this would work on the mk902 ?
                            Should work replacing kernel.img with a jellybean kernel for the mk902. I´m not sure about wifi and bluetooth though, not aware what chipset is used.
                              New update.
                              03/01/2016 V1.3 :
                              - Clean Base
                              - Fixed Storage
                              - Disabled screen off, added missing power module which caused reboots.
                              - Improved video performance
                              Build is smooth & stable. Now to team up with a kernel dev to get bluetooth working and improve performance.
